Date/Time: Fri, 18 Sep 2026 21:33:57 +0000
Accurate go to one define date with different timeframe
View Count: 1317
| [2015-03-28 10:48:33] |
| User17064 - Posts: 70 |
Hi SC support, For example, If I am looking in EUR/USD 4H timeframe at Jan.1st 2014, then want to zoom in 1M timeframe. When I click the 1M TF button in SC, then I still need to scroll to the left and need to adjust. Could SC has some function that I could select one 4H bar and zoom in this 4H bar. Or like MT4 it has an small arrow in the bottom of the screen, user could set the defined date and change the timeframe easily. Hope I have expressed myself well. Thank you |
| [2015-03-30 09:08:36] |
This is the general procedure to accomplish this: Scroll the chart to 1 bar after the last bar you want to view. Decrease the timeframe to 1 Minute or whatever detail that you require. Scroll the chart back one bar. The bars displayed, will be bars which are contained in the bar that you wanted to zoom in to. Increase or decrease the bar spacing as required by dragging along the timescale at the bottom of the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-30 09:09:06
