Date/Time: Tue, 29 Sep 2026 05:52:36 +0000
automatically displaying H+L/2 of the previous bar
View Count: 1217
| [2015-03-23 22:21:21] |
| Seanz - Posts: 17 |
I'm using range bars and would like to have a line at the midpoint of the previous bar automatically draw every time a new bar begins. Could someone please tell me how to accomplish this? many thanks!
| [2015-03-24 08:18:22] |
| Glyn - Posts: 20 |
You might like to try applying a Simple Moving Average with Input Data set to HL Ave and Length = 1. Select a suitable Draw Style such as Point, Dash or Stair Step. This method will also draw the provisional 50% level of the current bar.
| [2015-03-24 08:52:56] |
| Glyn - Posts: 20 |
Should have also said that if you want to display the 50% level of the previous bar on the current bar, set Displacement (on the Subgraphs Tab) to +1.
