Date/Time: Tue, 29 Sep 2026 05:52:35 +0000
Candlestick Chart versus PNF with X and O's
View Count: 1491
| [2015-03-23 19:11:43] |
| User35326 - Posts: 57 |
SC: I would like to be able to do a PNF chart then create the bar as a candlestick instead of the X's and the O's. In other words, the candle would be green for up or red for down just like a normal candlestick except, it would not be based on a 5 minute chart, for example. instead the candle would be based upon the requirements set in the PNF study -- ie, the box size and reversal size. I hope this makes sense to you. How do I do this? Thanks in advance for the great charts. Date Time Of Last Edit: 2015-03-23 20:06:23
| [2015-03-24 04:10:02] |
You need to change the Graph Draw Type for the Point and Figure study to Candlestick Bars: Graph Draw Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-24 04:10:56
