Date/Time: Thu, 15 Oct 2026 09:05:24 +0000
Processor / Core Assignments
View Count: 1295
[2015-03-20 13:46:46]
Richard Novak - Posts: 27
For my trading system I'm using a dual Xeon processor system with 8 cores and I was wondering if there is anyway to distribute the processing between CPUs / cores? I noticed that during loading of charts the processing is fairly evenly distributed across the processors / cores. After the charts have been loaded, the bulk of the processing is being performed by a single CPU / core.
[2015-03-20 15:31:32]
Originally we did not have an answer to this, but actually there is a solution to this by using multiple copies of Sierra Chart and sharing data between them. Refer to the Introduction section here:
Using Multiple Data and Trading Services at the Same Time: Introduction
[2015-03-20 16:30:22]
I'm currently using the SierraChart package offered through Infinity Futures / Transact. Is it possible to run multiple versions of that Infinity version of SierraChart on the same computer? I asked my broker and he didn't think it was possible.
[2015-03-23 17:48:02]
To install multiple copies of Sierra Chart on your system, you need a direct account as explained here:
Direct Sierra Chart Account
