Date/Time: Sat, 26 Sep 2026 05:12:21 +0000
DOM (installed on the chart) covers the bars
View Count: 1481
| [2015-03-19 13:48:08] |
| User87085 - Posts: 7 |
hello I still can not find a setting where I could indent (distance) from the range bar to horizontal grid (price range) because the DOM (installed on the chart) covers the bars thank you https://drive.google.com/file/d/0ByIARFk7ChfdM0w3WlRRS3E3WTg/view?usp=sharing |
| [2015-03-19 15:30:05] |
| ganz - Posts: 1048 |
User87085 http://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ScrollingTheChart |
| [2015-03-19 17:19:15] |
Refer to: Working With Charts: Scrolling The Chart and Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
