Date/Time: Wed, 23 Sep 2026 05:03:20 +0000
4 RANGE
View Count: 1849
[2015-03-17 07:13:52]
User87085 - Posts: 7
hello
why when I put 4 tick range makes me see these errors (I use Rithmich data feed)? Where is the problem?
thanks
https://drive.google.com/file/d/0ByIARFk7ChfdMGNfNENsNk05UzQ/view?usp=sharing
[2015-03-17 09:23:12]
https://drive.google.com/file/d/0ByIARFk7ChfdUDlnNkVGT0NMdEE/view?usp=sharing
sorry
but I have not even traded, and I have not used any trailing stop
it has some bugs, I think
visualization is not one that should be, it is very important, because I lost confidence in the fact that I can see
if I put the range 4 tiks, why it shows differently?
thanks
[2015-03-17 09:27:36]
We apologize. That answer was meant for another thread. It has been deleted.
[2015-03-17 17:12:19]
There are two things that you need to do.
You need to have a tick by tick data configuration:
And you also need to use the Sierra Chart Exchange Data Feed for the recent 10 minutes of data to have bid volume and ask volume. Refer to this page:
