Date/Time: Sat, 26 Sep 2026 05:12:30 +0000
indicator update
View Count: 1186
| [2015-03-16 13:16:14] |
| stephensmart - Posts: 51 |
Hi, how do i set my charts up so that indicators are only updated on a bar close not while the bar is forming?
| [2015-03-16 19:54:41] |
This is not supported by Sierra Chart unless the studies you work with are modified to specifically work this way. If you want to modify them refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-03-19 14:10:07] |
| Sawtooth - Posts: 4354 |
You can easily do this with the Spreadsheet Study study. Hide the indicator study, and add the Spreadsheet Study study. Set the Chart Region to 1, set the Number of Rows to 10, and use this formula in cell K3: =IF(ROW()=3,0,AA3) where the indicator is in column AA. If you want the previous indicator value to extend to the current bar, use this formula instead: =IF(ROW()=3,AA4,AA3) |
