Date/Time: Wed, 23 Sep 2026 05:04:13 +0000
Which data feed goes back further than 2007?
View Count: 1373
[2015-03-16 12:18:49]
User34124 - Posts: 289
Ideally to about 2000 or 2001
[2015-03-16 17:41:51]
Sierra Chart - Max - Posts: 5969
Do you need tick, minute or daily data?
Sierra Chart Support
Date Time Of Last Edit: 2015-03-17 00:16:59
[2015-03-16 19:11:32]
Daily would be perfect
[2015-03-16 19:18:53]
Use the Sierra Chart Historical Data Service:
[2015-03-16 22:56:54]
Oh yes sorry I checked this, but it does not have the majority of the pairs in 'FX Stats' from what I can see? Things like JPY-X and USDX ... are these specific to FXCM only?
[2015-03-17 00:33:09]
The FX stats do not go far back in time.
For the US dollar index, use $DXY to go far back in time.
[2015-03-17 07:07:49]
OK thanks so just lastly, how do I get $DXY. What feeds is this on
[2015-03-17 07:37:59]
You can open a Historical Daily chart for this symbol using most any Data or Trading service since most services will map the historical daily data request to the Sierra Chart Historical Data service for this symbol.
You can use:
SC Historical Data
SC Forex Data
[2015-03-17 09:23:12]
Unfortunately, under SC Historical or Forex Data >> Indexes : I cannot find $DXY
[2015-03-17 17:13:26]
You will not see it listed you have to hand type into the Selected Symbol box in File >> Find Symbol.
