Date/Time: Thu, 24 Sep 2026 08:28:40 +0000
level 5
View Count: 1748
| [2013-05-29 08:54:10] |
You appear to be using Sierra Chart through an affiliate. Therefore, you will need a standard installation of Sierra Chart. Please download and install Sierra Chart from this page: https://www.sierrachart.com/index.php?l=doc/download.php When you start Sierra Chart, log in with the Sierra Chart login information you use on this support board and the one you have made a payment with. After the installation, follow the set up instructions here to use the Trading service you are using: http://www.sierrachart.com/index.php?l=doc/TransAct.php#SetupInstructions (You appear to be using TransAct) To access your existing data files, you will need to change or Data Files Folder in this new installation, to the data folder used by your other installation of Sierra Chart. This can be done through Global Settings >> General Settings >> Data Files Folder. Let us know if you need help with this step. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-29 08:54:52
