Date/Time: Thu, 17 Sep 2026 05:02:09 +0000
Multiple Instances of Sierra
View Count: 1450
| [2015-03-13 22:55:17] |
| Bitcoinadvisor - Posts: 14 |
Hello, I have a dedicated server running windows server 2012. I am using five installations of Sierra charts, split between them I have around 50 charts each running a study and outputting data to a text file. I seem to be getting performance issues with some installations of sierra becoming unresponsive to the degree that I need to reboot the server. Is sierra designed to run 24/7? Will a study run 24/7 on each chart on each installation of sierra? Whats the maximum number of active charts per installation? Is there a 64bit version that will take advantage of more memory and threading. Another option would be to rent another server to spread the load, however i thought i would ask to see if anyone else has a solution. thanks Andrew |
| [2015-03-14 00:03:10] |
Sounds like you are probably using a custom study you created. So we recommend checking the custom study for performance issues and also refer to help topic 30: http://www.sierrachart.com/index.php?page=doc/helpdetails30.html In regards to your questions, there are no limitations that you are asking about. There is not a 64-bit version and we see no reason why it would make any difference. Sierra Chart can run extremely fast with what you are doing. There should be 0% performance issues. We just recommend keeping the Chart Update Interval above 200 ms and while connected to your server, avoid having too many chart windows visible at once. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-14 00:04:30
