Date/Time: Thu, 17 Sep 2026 04:09:24 +0000
Join Intraday Data finishes then msg says "join data canceled"?
View Count: 1108
| [2015-03-13 15:19:44] |
| nth - Posts: 46 |
Attempting "join" old intraday data file (YMH15.scid) to "write joined data to:" new intraday data file YMM15.scid "using rollover rules for transition". Join progress bar completes and then gives msg of "The join was cancelled"? Help? Thx, nth |
| [2015-03-13 17:55:26] |
| nth - Posts: 46 |
Never mind... I got it to work. Sorry to bother you all.
| [2015-03-13 17:58:10] |
OK good. If you still needed help, we would need to see the Message Log which would contain more information about the problem.
