Date/Time: Thu, 17 Sep 2026 04:09:15 +0000
Different values
View Count: 1126
| [2015-03-13 13:49:53] |
| nicktrader - Posts: 811 |
The attached file show three times a cut out of a D1 chart from yesterday. No 1 is my reference datafeed (Visual Chart). No 2 and 3 are two different brokers but the same chart software ==>> Sierra Charts :-). No 1 and No 2 contain nearly the same values however not the volume value. No 1 = 130,850 - no 2 = 96,721. Where is that difference coming from? Now I'd like to compare no 2 and no 3. As I wrote - same platform ==>> SC. After starting the platforms I get the same data for a daily chart as in no 2. However. By changing a M15 chart (example) in a Daily chart in no 3 I get new data as you see in no 3 esp. wrong data for LAST (this change works only in no.3 - in no. 2 no change in data). The only thing I really know that the data of no. 1 are correct. What can I do to get correct data for volume? |
Attachment Deleted. |
| [2015-03-14 02:15:55] |
Refer to help topic 43 here: https://www.sierrachart.com/index.php?page=doc/helpdetails43.html#h43.7 In the case of the EUREX, for the volume on the Daily charts, the next day's volume is reported for the bar previous to that bar. This is a problem with the data provider we have. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
