Date/Time: Thu, 17 Sep 2026 04:08:50 +0000
objects not copying to other charts
View Count: 1102
| [2015-03-13 10:37:11] |
| User22153 - Posts: 46 |
Hello Support, Objects are not copying to other charts when I put the chart number under 'Char Settings - Advanced Settings 2 - Copy Chart Drawings From Charts #'s:' Rectangles, fibs etc are not copying to my main chart. Thanks |
| [2015-03-13 17:14:11] |
Refer to this section here: Chart Settings: What to Do If Chart Drawings Do Not Copy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
