Date/Time: Thu, 17 Sep 2026 04:09:17 +0000
[User Discussion] - Scaling Request for Zigzag Cumulative Volume
View Count: 1316
| [2015-03-13 02:20:06] |
| Acro - Posts: 459 |
Hi, I love the zigzag volume "triangles" under a chart, but for thinner markets the lack of a scaling option means that the volume is very hard to see at all. For example, on today's Aus 200 SPI there were three to four pushes down, which should be clearly visible in red triangles on the attached chart but it's very, very hard to see any triangles at all. If there were a scaling option to increase the size of the graphical representation it would make it much more useful in my humble opinion. Thanks for considering this |
| [2015-03-13 03:32:28] |
Looks like a custom study you are using. First review the settings for studies here: Chart Studies: Study Settings Window And if you cannot find a setting to do what you need, contact the developer of the study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-03-13 18:28:09] |
| George - Posts: 60 |
Try increasing your bar spacing to push that 8900 volume on the left part of your chart off of the screen, then I think the current session ZZ volume will scale properly.
| [2015-03-14 03:33:18] |
| Acro - Posts: 459 |
Cheers George. Didn't think of that |
