Date/Time: Thu, 17 Sep 2026 04:09:25 +0000
referenced study not getting data
View Count: 1167
| [2015-03-13 00:56:05] |
| onnb - Posts: 666 |
I have a study that references a subgraph on another study using input.SetStudySubgraphValues(...) and GetStudyArrayUsingID When I do a reload and recalculation, I get all zeros (insert). This is also the case if I change study settings and return to the chart. If I now do a recalc the values are received ok - (cntl+insert). I am referencing the SC built in Line study. The referencing study has calculation precedence set to low. I am on build 1235. Any ideas? |
| [2015-03-13 02:46:16] |
Clearly there still is some study calculation precedence issue. Without knowing exactly what you are doing we cannot comment on it. Have a look at the rules here: Chart Studies: Study Calculation Precedence And Related Issues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-03-13 05:32:15] |
| onnb - Posts: 666 |
Found it - its related to the "Display as Main Price Graph" setting for the study that is doing the referencing. If that is set, the study is calculated first regardless of references and precedence levels? |
| [2015-03-13 07:59:49] |
Yes that does make sense.
