Date/Time: Thu, 17 Sep 2026 04:13:16 +0000
Request/Suggestion
View Count: 1172
| [2015-03-12 21:25:50] |
| User94199 - Posts: 13 |
Hello, Would it be difficult to add setting for size of Volume by price study, size based on amount of bars? Something like lock fill space has. Right now it is only % of window or period. I'm using change spacing as zoom in zoom out, with set X&Y relationship, and when I zoom out, Volume profile gets too oblong to read, and overlaps with price. Thank you for all the support anyway, great work on last VbP rework. |
| [2015-03-13 19:11:26] |
We will see about this.
