Date/Time: Thu, 17 Sep 2026 04:09:25 +0000
[User Discussion] - Quoteboard resets
View Count: 1290
[2015-03-12 18:56:03]
rhovega - Posts: 279
Every time SC losses connectivity (even for half a second) the SC Quoteboard resets the percentage changes for the day.
This applies to stocks and currencies, not to futures (no problem with futures).
I am attaching two SC Quoteboards and one IB quoteboard for illustration purposes. Screenshots taken 1 minute apart.
See the following:
EUR/GBP: +1.4% on SC, +1.09% on IB
EWW: +0.55% on SC, +1.43% on IB
Would it be possible to find a solution to this?
imageSC1.png / V - Attached On 2015-03-12 18:55:26 UTC - Size: 61.63 KB - 453 views
imageSC2.png / V - Attached On 2015-03-12 18:55:30 UTC - Size: 56.47 KB - 507 views
imageIB1.png / V - Attached On 2015-03-12 18:55:39 UTC - Size: 50.12 KB - 481 views
[2015-03-12 19:55:25]
The calculation is based upon the data from Interactive Brokers. Specifically the Net Change calculations use the "Close" tick type. This is a value direct from TWS.
[2015-03-12 20:02:00]
Then why is it not displaying the same information as TWS?
It resets to zero on every disconnection. TWS does not.
[2015-03-12 20:05:05]
Interactive Brokers must not be providing the previous close price through the API.
[2015-03-12 20:30:20]
Do you have the capacity to check that? So I may contact IB. Understand not much to do if they are not, but would still be good to know.
[2015-03-13 00:30:22]
We did spend time, about 30 minutes reviewing the various fields of data and messages to see if there is any field we are missing which contains the previous day's close/settlement price and there is nothing. So Sierra Chart's integration with TWS is complete and correct.
