Date/Time: Sun, 20 Sep 2026 05:27:29 +0000
RLM-MM5 still not updating correctly
View Count: 1189
| [2015-03-12 18:29:55] |
| User74987 - Posts: 16 |
Ok, yesterday you told me I had too many contracts open for OEC even tho it was working before with more. Today, I updated my charts for only 5 contracts, and rolled them over and my RLM-MM5 charts are still not updating. would you please look again? here's my log. THanks. Software version: 1239 | 2015-03-12 13:05:18 Uses New Spreadsheets | 2015-03-12 13:05:18 Usage end date: 2015-04-09 | 2015-03-12 13:05:18 Enabled for: Advanced Features. | 2015-03-12 13:05:18 Enabled for: Advanced Features 2. | 2015-03-12 13:05:18 Enabled for: Sierra Chart Historical Data Service. | 2015-03-12 13:05:18 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-03-12 13:05:18 Active service: Open E Cry FIX | 2015-03-12 13:05:18 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-03-12 13:05:18 2015-03-12 13:05:18 Local computer clock time | 2015-03-12 13:05:18 2015-03-12 18:05:18 GMT time | 2015-03-12 13:05:18 2015-03-12 13:05:18 Time zone adjusted time | 2015-03-12 13:05:18 Time difference to server time: 1 seconds. | 2015-03-12 13:05:18 Program path: C:\SierraChart4Stage5\ | 2015-03-12 13:05:18 Data Files path: C:\SierraChart4Stage5\Data\ | 2015-03-12 13:05:18 OS Version Number: 6.1 | 2015-03-12 13:05:18 Locale Information: C | 2015-03-12 13:05:18 Checking for new symbol settings for oec | 2015-03-12 13:05:18 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-03-12 13:05:18 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-03-12 13:05:18 Symbol settings are up-to-date for oec | 2015-03-12 13:05:18 Files to Open on Start up | Opening file: MASATChartDefault0913.cht | 2015-03-12 13:05:21 Date rule based rollover from GCLG5 to next contract occurs at 2015-01-19. | 2015-03-12 13:05:21 Date rule based rollover from GCLH5 to next contract occurs at 2015-02-19. | 2015-03-12 13:05:21 Date rule based rollover from GCLJ5 to next contract occurs at 2015-03-19. | 2015-03-12 13:05:21 Checking Intraday data file for symbol GCLG5 for the date range from 2014-12-19 to 2015-01-19. | 2015-03-12 13:05:21 Checking Daily data file for symbol GCLG5 for the date range from 2014-12-19 to 2015-01-19. | 2015-03-12 13:05:21 Checking Intraday data file for symbol GCLH5 for the date range from 2015-01-19 to 2015-02-19. | 2015-03-12 13:05:21 Checking Daily data file for symbol GCLH5 for the date range from 2015-01-19 to 2015-02-19. | 2015-03-12 13:05:21 Checking Intraday data file for symbol GCLJ5 for the date range from 2015-02-19 to 0. | 2015-03-12 13:05:21 Checking Daily data file for symbol GCLJ5 for the date range from 2015-02-19 to 2015-03-12. | 2015-03-12 13:05:21 GCLJ5 [CB] 500 Trades #4 | Symbols used for continuous contract chart: | 2015-03-12 13:05:21 GCLG5 | 2015-03-12 13:05:21 GCLH5 | 2015-03-12 13:05:21 GCLJ5 | 2015-03-12 13:05:21 GCLJ5 [CB] 500 Trades #4: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:05:21 GCLJ5 [CB] 500 Trades #4: GCLG5 Open price on 2015-01-19 is 48.69. | 2015-03-12 13:05:21 GCLJ5 [CB] 500 Trades #4: GCLH5 Open price on 2015-01-19 is 49.2. | 2015-03-12 13:05:21 GCLJ5 [CB] 500 Trades #4: GCLG5 price difference to GCLH5 is 0.50999999. | 2015-03-12 13:05:21 GCLJ5 [CB] 500 Trades #4: GCLH5 Open price on 2015-02-19 is 50.55. | 2015-03-12 13:05:21 GCLJ5 [CB] 500 Trades #4: GCLJ5 Open price on 2015-02-19 is 51.25. | 2015-03-12 13:05:21 GCLJ5 [CB] 500 Trades #4: GCLH5 price difference to GCLJ5 is 0.69999999. | 2015-03-12 13:05:21 GCLJ5 [CB] 500 Trades #4: Back adjust amount for symbol GCLG5 is 1.21. | 2015-03-12 13:05:21 GCLJ5 [CB] 500 Trades #4: Back adjust amount for symbol GCLH5 is 0.69999999. | 2015-03-12 13:05:21 Date rule based rollover from ESH5 to next contract occurs at 2015-03-12. | 2015-03-12 13:05:21 Date rule based rollover from ESM5 to next contract occurs at 2015-06-11. | 2015-03-12 13:05:21 Checking Intraday data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:21 Checking Daily data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:21 Checking Intraday data file for symbol ESM5 for the date range from 2015-03-12 to 0. | 2015-03-12 13:05:21 Checking Daily data file for symbol ESM5 for the date range from 2015-03-12 to 2015-03-12. | 2015-03-12 13:05:21 ESM5 [CB] Renko 4t #1 | Symbols used for continuous contract chart: | 2015-03-12 13:05:21 ESH5 | 2015-03-12 13:05:21 ESM5 | 2015-03-12 13:05:21 ESM5 [CB] Renko 4t #1: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:05:21 ESM5 [CB] Renko 4t #1: ESH5 Open price on 2015-03-12 is 2042. | 2015-03-12 13:05:21 ESM5 [CB] Renko 4t #1: ESM5 Open price on 2015-03-12 is 2034.75. | 2015-03-12 13:05:21 ESM5 [CB] Renko 4t #1: ESH5 price difference to ESM5 is -7.25. | 2015-03-12 13:05:21 ESM5 [CB] Renko 4t #1: Back adjust amount for symbol ESH5 is -7.25. | 2015-03-12 13:05:21 Files to Open on Start up | Opening file: Victors Chartbook 10-01-2013.cht | 2015-03-12 13:05:21 Date rule based rollover from RLM-MH5 to next contract occurs at 2015-03-12. | 2015-03-12 13:05:21 Date rule based rollover from RLM-MM5 to next contract occurs at 2015-06-11. | 2015-03-12 13:05:21 Checking Intraday data file for symbol RLM-MH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:21 Checking Daily data file for symbol RLM-MH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:21 Checking Intraday data file for symbol RLM-MM5 for the date range from 2015-03-12 to 0. | 2015-03-12 13:05:21 Checking Daily data file for symbol RLM-MM5 for the date range from 2015-03-12 to 2015-03-12. | 2015-03-12 13:05:21 RLM-MM5 [CB] 220 Trades #1 | Symbols used for continuous contract chart: | 2015-03-12 13:05:21 RLM-MH5 | 2015-03-12 13:05:21 RLM-MM5 | 2015-03-12 13:05:21 RLM-MM5 [CB] 220 Trades #1: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:05:21 RLM-MM5 [CB] 220 Trades #1: RLM-MH5 Open price on 2015-03-12 is 1216.9. | 2015-03-12 13:05:21 RLM-MM5 [CB] 220 Trades #1: RLM-MM5 Open price on 2015-03-12 is 1211.6. | 2015-03-12 13:05:21 RLM-MM5 [CB] 220 Trades #1: RLM-MH5 price difference to RLM-MM5 is -5.3000002. | 2015-03-12 13:05:21 RLM-MM5 [CB] 220 Trades #1: Back adjust amount for symbol RLM-MH5 is -5.3000002. | 2015-03-12 13:05:21 Date rule based rollover from RLM-MH5 to next contract occurs at 2015-03-12. | 2015-03-12 13:05:21 Date rule based rollover from RLM-MM5 to next contract occurs at 2015-06-11. | 2015-03-12 13:05:21 Checking Intraday data file for symbol RLM-MH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:21 Checking Daily data file for symbol RLM-MH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:21 Checking Intraday data file for symbol RLM-MM5 for the date range from 2015-03-12 to 0. | 2015-03-12 13:05:21 Checking Daily data file for symbol RLM-MM5 for the date range from 2015-03-12 to 2015-03-12. | 2015-03-12 13:05:21 RLM-MM5 [CB] 880 Trades #4 | Symbols used for continuous contract chart: | 2015-03-12 13:05:21 RLM-MH5 | 2015-03-12 13:05:21 RLM-MM5 | 2015-03-12 13:05:21 RLM-MM5 [CB] 880 Trades #4: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:05:21 RLM-MM5 [CB] 880 Trades #4: RLM-MH5 Open price on 2015-03-12 is 1216.9. | 2015-03-12 13:05:21 RLM-MM5 [CB] 880 Trades #4: RLM-MM5 Open price on 2015-03-12 is 1211.6. | 2015-03-12 13:05:21 RLM-MM5 [CB] 880 Trades #4: RLM-MH5 price difference to RLM-MM5 is -5.3000002. | 2015-03-12 13:05:21 RLM-MM5 [CB] 880 Trades #4: Back adjust amount for symbol RLM-MH5 is -5.3000002. | 2015-03-12 13:05:21 Date rule based rollover from RLM-MH5 to next contract occurs at 2015-03-12. | 2015-03-12 13:05:21 Date rule based rollover from RLM-MM5 to next contract occurs at 2015-06-11. | 2015-03-12 13:05:21 Checking Intraday data file for symbol RLM-MH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:21 Checking Daily data file for symbol RLM-MH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:21 Checking Intraday data file for symbol RLM-MM5 for the date range from 2015-03-12 to 0. | 2015-03-12 13:05:21 Checking Daily data file for symbol RLM-MM5 for the date range from 2015-03-12 to 2015-03-12. | 2015-03-12 13:05:21 RLM-MM5 [CB] 500 Trades #2 | Symbols used for continuous contract chart: | 2015-03-12 13:05:21 RLM-MH5 | 2015-03-12 13:05:21 RLM-MM5 | 2015-03-12 13:05:21 RLM-MM5 [CB] 500 Trades #2: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:05:21 RLM-MM5 [CB] 500 Trades #2: RLM-MH5 Open price on 2015-03-12 is 1216.9. | 2015-03-12 13:05:21 RLM-MM5 [CB] 500 Trades #2: RLM-MM5 Open price on 2015-03-12 is 1211.6. | 2015-03-12 13:05:21 RLM-MM5 [CB] 500 Trades #2: RLM-MH5 price difference to RLM-MM5 is -5.3000002. | 2015-03-12 13:05:21 RLM-MM5 [CB] 500 Trades #2: Back adjust amount for symbol RLM-MH5 is -5.3000002. | 2015-03-12 13:05:21 Files to Open on Start up | Opening file: IOAMT rebuild 10222014.cht | 2015-03-12 13:05:21 Date rule based rollover from ESH5 to next contract occurs at 2015-03-12. | 2015-03-12 13:05:21 Date rule based rollover from ESM5 to next contract occurs at 2015-06-11. | 2015-03-12 13:05:21 Checking Intraday data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:21 Checking Daily data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:21 Checking Intraday data file for symbol ESM5 for the date range from 2015-03-12 to 0. | 2015-03-12 13:05:21 Checking Daily data file for symbol ESM5 for the date range from 2015-03-12 to 2015-03-12. | 2015-03-12 13:05:21 ESM5 [CB] 3.50 Range #1 | Symbols used for continuous contract chart: | 2015-03-12 13:05:21 ESH5 | 2015-03-12 13:05:21 ESM5 | 2015-03-12 13:05:21 ESM5 [CB] 3.50 Range #1: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:05:21 ESM5 [CB] 3.50 Range #1: ESH5 Open price on 2015-03-12 is 2042. | 2015-03-12 13:05:21 ESM5 [CB] 3.50 Range #1: ESM5 Open price on 2015-03-12 is 2034.75. | 2015-03-12 13:05:21 ESM5 [CB] 3.50 Range #1: ESH5 price difference to ESM5 is -7.25. | 2015-03-12 13:05:21 ESM5 [CB] 3.50 Range #1: Back adjust amount for symbol ESH5 is -7.25. | 2015-03-12 13:05:21 Date rule based rollover from ESH4 to next contract occurs at 2014-03-13. | 2015-03-12 13:05:21 Date rule based rollover from ESM4 to next contract occurs at 2014-06-12. | 2015-03-12 13:05:21 Date rule based rollover from ESU4 to next contract occurs at 2014-09-11. | 2015-03-12 13:05:21 Date rule based rollover from ESZ4 to next contract occurs at 2014-12-11. | 2015-03-12 13:05:21 Date rule based rollover from ESH5 to next contract occurs at 2015-03-12. | 2015-03-12 13:05:21 Date rule based rollover from ESM5 to next contract occurs at 2015-06-11. | 2015-03-12 13:05:21 Checking Daily data file for symbol ESH4 for the date range from 2013-12-12 to 2014-03-13. | 2015-03-12 13:05:21 Checking Daily data file for symbol ESM4 for the date range from 2014-03-13 to 2014-06-12. | 2015-03-12 13:05:21 Checking Daily data file for symbol ESU4 for the date range from 2014-06-12 to 2014-09-11. | 2015-03-12 13:05:21 Checking Daily data file for symbol ESZ4 for the date range from 2014-09-11 to 2014-12-11. | 2015-03-12 13:05:21 Checking Daily data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:21 Checking Daily data file for symbol ESM5 for the date range from 2015-03-12 to 2015-03-12. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2 | Symbols used for continuous contract chart: | 2015-03-12 13:05:21 ESH4 | 2015-03-12 13:05:21 ESM4 | 2015-03-12 13:05:21 ESU4 | 2015-03-12 13:05:21 ESZ4 | 2015-03-12 13:05:21 ESH5 | 2015-03-12 13:05:21 ESM5 | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: ESH4 Open price on 2014-03-13 is 1868.75. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: ESM4 Open price on 2014-03-13 is 1861.5. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: ESH4 price difference to ESM4 is -7.25. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: ESM4 Open price on 2014-06-12 is 1943.75. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: ESU4 Open price on 2014-06-12 is 1936.75. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: ESM4 price difference to ESU4 is -7. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: ESU4 Open price on 2014-09-11 is 1994.5. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: ESZ4 Open price on 2014-09-11 is 1986.75. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: ESU4 price difference to ESZ4 is -7.75. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: ESZ4 Open price on 2014-12-11 is 2026.25. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: ESH5 Open price on 2014-12-11 is 2019.75. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: ESZ4 price difference to ESH5 is -6.5. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: ESH5 Open price on 2015-03-12 is 2042. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: ESM5 Open price on 2015-03-12 is 2034.75. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: ESH5 price difference to ESM5 is -7.25. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: Back adjust amount for symbol ESH4 is -35.75. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: Back adjust amount for symbol ESM4 is -28.5. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: Back adjust amount for symbol ESU4 is -21.5. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: Back adjust amount for symbol ESZ4 is -13.75. | 2015-03-12 13:05:21 ESM5 [CB] Daily #2: Back adjust amount for symbol ESH5 is -7.25. | 2015-03-12 13:05:21 Date rule based rollover from ESZ4 to next contract occurs at 2014-12-11. | 2015-03-12 13:05:21 Date rule based rollover from ESH5 to next contract occurs at 2015-03-12. | 2015-03-12 13:05:21 Date rule based rollover from ESM5 to next contract occurs at 2015-06-11. | 2015-03-12 13:05:21 Checking Intraday data file for symbol ESZ4 for the date range from 2014-09-11 to 2014-12-11. | 2015-03-12 13:05:21 Checking Daily data file for symbol ESZ4 for the date range from 2014-09-11 to 2014-12-11. | 2015-03-12 13:05:21 Checking Intraday data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:21 Checking Daily data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:21 Checking Intraday data file for symbol ESM5 for the date range from 2015-03-12 to 0. | 2015-03-12 13:05:21 Checking Daily data file for symbol ESM5 for the date range from 2015-03-12 to 2015-03-12. | 2015-03-12 13:05:21 ESM5 [CB] #4 | Symbols used for continuous contract chart: | 2015-03-12 13:05:21 ESZ4 | 2015-03-12 13:05:21 ESH5 | 2015-03-12 13:05:21 ESM5 | 2015-03-12 13:05:21 ESM5 [CB] #4: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:05:21 ESM5 [CB] #4: ESZ4 Open price on 2014-12-11 is 2026.25. | 2015-03-12 13:05:21 ESM5 [CB] #4: ESH5 Open price on 2014-12-11 is 2019.75. | 2015-03-12 13:05:21 ESM5 [CB] #4: ESZ4 price difference to ESH5 is -6.5. | 2015-03-12 13:05:21 ESM5 [CB] #4: ESH5 Open price on 2015-03-12 is 2042. | 2015-03-12 13:05:21 ESM5 [CB] #4: ESM5 Open price on 2015-03-12 is 2034.75. | 2015-03-12 13:05:21 ESM5 [CB] #4: ESH5 price difference to ESM5 is -7.25. | 2015-03-12 13:05:21 ESM5 [CB] #4: Back adjust amount for symbol ESZ4 is -13.75. | 2015-03-12 13:05:21 ESM5 [CB] #4: Back adjust amount for symbol ESH5 is -7.25. | 2015-03-12 13:05:21 Date rule based rollover from ESU4 to next contract occurs at 2014-09-11. | 2015-03-12 13:05:22 Date rule based rollover from ESZ4 to next contract occurs at 2014-12-11. | 2015-03-12 13:05:22 Date rule based rollover from ESH5 to next contract occurs at 2015-03-12. | 2015-03-12 13:05:22 Date rule based rollover from ESM5 to next contract occurs at 2015-06-11. | 2015-03-12 13:05:22 Checking Intraday data file for symbol ESU4 for the date range from 2014-06-12 to 2014-09-11. | 2015-03-12 13:05:22 Checking Daily data file for symbol ESU4 for the date range from 2014-06-12 to 2014-09-11. | 2015-03-12 13:05:22 Checking Intraday data file for symbol ESZ4 for the date range from 2014-09-11 to 2014-12-11. | 2015-03-12 13:05:22 Checking Daily data file for symbol ESZ4 for the date range from 2014-09-11 to 2014-12-11. | 2015-03-12 13:05:22 Checking Intraday data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:22 Checking Daily data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:22 Checking Intraday data file for symbol ESM5 for the date range from 2015-03-12 to 0. | 2015-03-12 13:05:22 Checking Daily data file for symbol ESM5 for the date range from 2015-03-12 to 2015-03-12. | 2015-03-12 13:05:22 ESM5 [CB] #7 | Symbols used for continuous contract chart: | 2015-03-12 13:05:22 ESU4 | 2015-03-12 13:05:22 ESZ4 | 2015-03-12 13:05:22 ESH5 | 2015-03-12 13:05:22 ESM5 | 2015-03-12 13:05:22 ESM5 [CB] #7: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:05:22 ESM5 [CB] #7: ESU4 Open price on 2014-09-11 is 1994.5. | 2015-03-12 13:05:22 ESM5 [CB] #7: ESZ4 Open price on 2014-09-11 is 1986.75. | 2015-03-12 13:05:22 ESM5 [CB] #7: ESU4 price difference to ESZ4 is -7.75. | 2015-03-12 13:05:22 ESM5 [CB] #7: ESZ4 Open price on 2014-12-11 is 2026.25. | 2015-03-12 13:05:22 ESM5 [CB] #7: ESH5 Open price on 2014-12-11 is 2019.75. | 2015-03-12 13:05:22 ESM5 [CB] #7: ESZ4 price difference to ESH5 is -6.5. | 2015-03-12 13:05:22 ESM5 [CB] #7: ESH5 Open price on 2015-03-12 is 2042. | 2015-03-12 13:05:22 ESM5 [CB] #7: ESM5 Open price on 2015-03-12 is 2034.75. | 2015-03-12 13:05:22 ESM5 [CB] #7: ESH5 price difference to ESM5 is -7.25. | 2015-03-12 13:05:22 ESM5 [CB] #7: Back adjust amount for symbol ESU4 is -21.5. | 2015-03-12 13:05:22 ESM5 [CB] #7: Back adjust amount for symbol ESZ4 is -13.75. | 2015-03-12 13:05:22 ESM5 [CB] #7: Back adjust amount for symbol ESH5 is -7.25. | 2015-03-12 13:05:22 Date rule based rollover from ESZ4 to next contract occurs at 2014-12-11. | 2015-03-12 13:05:22 Date rule based rollover from ESH5 to next contract occurs at 2015-03-12. | 2015-03-12 13:05:22 Date rule based rollover from ESM5 to next contract occurs at 2015-06-11. | 2015-03-12 13:05:22 Checking Intraday data file for symbol ESZ4 for the date range from 2014-09-11 to 2014-12-11. | 2015-03-12 13:05:22 Checking Daily data file for symbol ESZ4 for the date range from 2014-09-11 to 2014-12-11. | 2015-03-12 13:05:22 Checking Intraday data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:22 Checking Daily data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:22 Checking Intraday data file for symbol ESM5 for the date range from 2015-03-12 to 0. | 2015-03-12 13:05:22 Checking Daily data file for symbol ESM5 for the date range from 2015-03-12 to 2015-03-12. | 2015-03-12 13:05:22 ESM5 [CB] 2500 Volume #8 | Symbols used for continuous contract chart: | 2015-03-12 13:05:22 ESZ4 | 2015-03-12 13:05:22 ESH5 | 2015-03-12 13:05:22 ESM5 | 2015-03-12 13:05:22 ESM5 [CB] 2500 Volume #8: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:05:22 ESM5 [CB] 2500 Volume #8: ESZ4 Open price on 2014-12-11 is 2026.25. | 2015-03-12 13:05:22 ESM5 [CB] 2500 Volume #8: ESH5 Open price on 2014-12-11 is 2019.75. | 2015-03-12 13:05:22 ESM5 [CB] 2500 Volume #8: ESZ4 price difference to ESH5 is -6.5. | 2015-03-12 13:05:22 ESM5 [CB] 2500 Volume #8: ESH5 Open price on 2015-03-12 is 2042. | 2015-03-12 13:05:22 ESM5 [CB] 2500 Volume #8: ESM5 Open price on 2015-03-12 is 2034.75. | 2015-03-12 13:05:22 ESM5 [CB] 2500 Volume #8: ESH5 price difference to ESM5 is -7.25. | 2015-03-12 13:05:22 ESM5 [CB] 2500 Volume #8: Back adjust amount for symbol ESZ4 is -13.75. | 2015-03-12 13:05:22 ESM5 [CB] 2500 Volume #8: Back adjust amount for symbol ESH5 is -7.25. | 2015-03-12 13:05:22 Intraday data recording state for symbol GCLJ5 is set to download pending. | 2015-03-12 13:05:22 HD Request # 2 | Downloading Intraday chart data for GCLJ5 to the file GCLJ5.scid. Service: oec | 2015-03-12 13:05:22 HD Request # 2 | Download start Date-Time: 2015-03-12 13:05:12.0 | 2015-03-12 13:05:22 HD Request # 2 | Using server: oec.sierracharts.com port 10149 | 2015-03-12 13:05:22 Socket (0) | Resolved address oec.sierracharts.com to IP 204.11.49.26 | 2015-03-12 13:05:22 Socket (2) | Connected. | 2015-03-12 13:05:22 HD Request # 2 | Sending historical data logon request message. | 2015-03-12 13:05:22 Intraday data recording state for symbol ESM5 is set to download pending. | 2015-03-12 13:05:22 Intraday data recording state for symbol RLM-MM5 is set to download pending. | 2015-03-12 13:05:22 HD Request # 3 | Downloading Historical Daily chart data for ESM5. Starting date: 2015-03-11. Service: oec | 2015-03-12 13:05:22 HD Request # 3 | Requesting historical Daily data for ESM15 starting at 2015-03-10 | 2015-03-12 13:05:22 HD Request # 3 | Receiving historical Daily data for ESM5 starting at 2015-03-10 | 2015-03-12 13:05:23 Writing historical Daily data for ESM5 to the file ESM5.dly | 2015-03-12 13:05:23 HD Request # 3 | Received 3 records from 2015-03-10 00:00:00 to 2015-03-12 00:00:00 (3.0 days) and wrote 2 records for ESM5 | 2015-03-12 13:05:23 HD Request # 3 | Daily download COMPLETE for ESM5. Completion time: 1s. Unique request ID: 4 | 2015-03-12 13:05:23 Removed historical data download ID 4 | 2015-03-12 13:05:23 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2015-03-12 13:05:12. Record interval: 0. Symbol: GCLJ5 | 2015-03-12 13:05:23 Socket (2) | Shutdown and closed. | 2015-03-12 13:05:23 The network socket for historical data has been closed. | 2015-03-12 13:05:23 Date rule based rollover from ESH4 to next contract occurs at 2014-03-13. | 2015-03-12 13:05:23 Date rule based rollover from ESM4 to next contract occurs at 2014-06-12. | 2015-03-12 13:05:23 Date rule based rollover from ESU4 to next contract occurs at 2014-09-11. | 2015-03-12 13:05:23 Date rule based rollover from ESZ4 to next contract occurs at 2014-12-11. | 2015-03-12 13:05:23 Date rule based rollover from ESH5 to next contract occurs at 2015-03-12. | 2015-03-12 13:05:23 Date rule based rollover from ESM5 to next contract occurs at 2015-06-11. | 2015-03-12 13:05:23 Checking Daily data file for symbol ESH4 for the date range from 2013-12-12 to 2014-03-13. | 2015-03-12 13:05:23 Checking Daily data file for symbol ESM4 for the date range from 2014-03-13 to 2014-06-12. | 2015-03-12 13:05:23 Checking Daily data file for symbol ESU4 for the date range from 2014-06-12 to 2014-09-11. | 2015-03-12 13:05:23 Checking Daily data file for symbol ESZ4 for the date range from 2014-09-11 to 2014-12-11. | 2015-03-12 13:05:23 Checking Daily data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:23 Checking Daily data file for symbol ESM5 for the date range from 2015-03-12 to 2015-03-12. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2 | Symbols used for continuous contract chart: | 2015-03-12 13:05:23 ESH4 | 2015-03-12 13:05:23 ESM4 | 2015-03-12 13:05:23 ESU4 | 2015-03-12 13:05:23 ESZ4 | 2015-03-12 13:05:23 ESH5 | 2015-03-12 13:05:23 ESM5 | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: ESH4 Open price on 2014-03-13 is 1868.75. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: ESM4 Open price on 2014-03-13 is 1861.5. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: ESH4 price difference to ESM4 is -7.25. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: ESM4 Open price on 2014-06-12 is 1943.75. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: ESU4 Open price on 2014-06-12 is 1936.75. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: ESM4 price difference to ESU4 is -7. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: ESU4 Open price on 2014-09-11 is 1994.5. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: ESZ4 Open price on 2014-09-11 is 1986.75. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: ESU4 price difference to ESZ4 is -7.75. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: ESZ4 Open price on 2014-12-11 is 2026.25. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: ESH5 Open price on 2014-12-11 is 2019.75. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: ESZ4 price difference to ESH5 is -6.5. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: ESH5 Open price on 2015-03-12 is 2042. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: ESM5 Open price on 2015-03-12 is 2034.75. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: ESH5 price difference to ESM5 is -7.25. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: Back adjust amount for symbol ESH4 is -35.75. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: Back adjust amount for symbol ESM4 is -28.5. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: Back adjust amount for symbol ESU4 is -21.5. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: Back adjust amount for symbol ESZ4 is -13.75. | 2015-03-12 13:05:23 ESM5 [CB] Daily #2: Back adjust amount for symbol ESH5 is -7.25. | 2015-03-12 13:05:23 HD Request # 2 | Historical data for GCLJ5 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-03-12 13:05:23 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCLJ5 | 2015-03-12 13:05:23 HD Request # 2 | Intraday download COMPLETE for GCLJ5. Completion time: 1s. Unique request ID: 1 | 2015-03-12 13:05:23 Removed historical data download ID 1 | 2015-03-12 13:05:23 HD Request # 4 | Downloading Intraday chart data for ESM5 to the file ESM5.scid. Service: oec | 2015-03-12 13:05:23 HD Request # 4 | Download start Date-Time: 2015-03-12 13:05:10.0 | 2015-03-12 13:05:23 HD Request # 4 | Using server: oec.sierracharts.com port 10149 | 2015-03-12 13:05:23 Socket (0) | Resolved address oec.sierracharts.com to IP 204.11.49.26 | 2015-03-12 13:05:23 Socket (3) | Connected. | 2015-03-12 13:05:23 HD Request # 4 | Sending historical data logon request message. | 2015-03-12 13:05:23 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2015-03-12 13:05:10. Record interval: 0. Symbol: ESM5 | 2015-03-12 13:05:23 HD Request # 4 | Historical data for ESM5 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-03-12 13:05:23 Socket (3) | Shutdown and closed. | 2015-03-12 13:05:23 The network socket for historical data has been closed. | 2015-03-12 13:05:23 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM5 | 2015-03-12 13:05:23 HD Request # 4 | Intraday download COMPLETE for ESM5. Completion time: 0s. Unique request ID: 2 | 2015-03-12 13:05:23 Removed historical data download ID 2 | 2015-03-12 13:05:23 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-03-12 13:05:23 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-03-12 13:05:23 HD Request # 5 | Downloading Intraday chart data for RLM-MM5 to the file RLM-MM5.scid. Service: oec | 2015-03-12 13:05:23 HD Request # 5 | Download start Date-Time: 2015-03-12 13:05:09.0 | 2015-03-12 13:05:23 HD Request # 5 | Using server: oec.sierracharts.com port 10149 | 2015-03-12 13:05:23 Chart #3 has tagged chart #5 for full recalculation. Chartbook: IOAMT rebuild 10222014.cht | 2015-03-12 13:05:23 Chart #5 is performing a full recalculation because it has been tagged. Chartbook: IOAMT rebuild 10222014.cht | 2015-03-12 13:05:23 Socket (0) | Resolved address oec.sierracharts.com to IP 204.11.49.26 | 2015-03-12 13:05:23 Socket (4) | Connected. | 2015-03-12 13:05:23 HD Request # 5 | Sending historical data logon request message. | 2015-03-12 13:05:23 HD Request # 5 | Requesting Intraday data. Start Date-Time: 2015-03-12 13:05:09. Record interval: 0. Symbol: RLM-MM5 | 2015-03-12 13:05:23 Socket (4) | Shutdown and closed. | 2015-03-12 13:05:23 The network socket for historical data has been closed. | 2015-03-12 13:05:23 HD Request # 5 | Historical data for RLM-MM5 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-03-12 13:05:23 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for RLM-MM5 | 2015-03-12 13:05:23 HD Request # 5 | Intraday download COMPLETE for RLM-MM5. Completion time: 0s. Unique request ID: 3 | 2015-03-12 13:05:23 Removed historical data download ID 3 | 2015-03-12 13:05:23 Open E Cry FIX | Connecting to trading server prod.openecry.com:9400. | 2015-03-12 13:05:24 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2015-03-12 13:05:24 OEC FIX Trading socket (5) | Connected. | 2015-03-12 13:05:24 OEC FIX Trading socket (5) | Starting SSL connection. | 2015-03-12 13:05:24 OEC FIX Trading socket (5) | SSL connection established. | 2015-03-12 13:05:25 OEC FIX Trading: Sending the Logon message. | 2015-03-12 13:05:25 OEC FIX Trading | Connected to trading server. | 2015-03-12 13:05:25 Open E Cry FIX | Connecting to market data server prod.openecry.com:9301. | 2015-03-12 13:05:25 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2015-03-12 13:05:25 OEC FAST Data socket (6) | Connected. | 2015-03-12 13:05:25 OEC FAST Data: Sending the Hello message. | 2015-03-12 13:05:25 OEC FAST Data: Sending the Logon message. | 2015-03-12 13:05:25 Open E Cry FIX | Connected to the market data server. | 2015-03-12 13:05:25 Open E Cry FIX | Connected. | 2015-03-12 13:05:25 Open E Cry FIX | Starting real-time market data updates for: ESM5. ID: 1 | 2015-03-12 13:05:25 Intraday data recording state for symbol ESM5 is set to download pending. | 2015-03-12 13:05:26 HD Request # 6 | Downloading Intraday chart data for ESM5 to the file ESM5.scid. Service: oec | 2015-03-12 13:05:26 HD Request # 6 | Download start Date-Time: 2015-03-12 13:05:10.0 | 2015-03-12 13:05:26 HD Request # 6 | Using server: oec.sierracharts.com port 10149 | 2015-03-12 13:05:26 Socket (0) | Resolved address oec.sierracharts.com to IP 204.11.49.26 | 2015-03-12 13:05:26 Open E Cry FIX | Starting real-time market data updates for: GCLJ5. ID: 2 | 2015-03-12 13:05:26 Intraday data recording state for symbol GCLJ5 is set to download pending. | 2015-03-12 13:05:26 Open E Cry FIX | Starting real-time market data updates for: RLM-MM5. ID: 3 | 2015-03-12 13:05:26 Intraday data recording state for symbol RLM-MM5 is set to download pending. | 2015-03-12 13:05:26 Socket (7) | Connected. | 2015-03-12 13:05:26 HD Request # 6 | Sending historical data logon request message. | 2015-03-12 13:05:26 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2015-03-12 13:05:10. Record interval: 0. Symbol: ESM5 | 2015-03-12 13:05:26 Date rule based rollover from ESH4 to next contract occurs at 2014-03-13. | 2015-03-12 13:05:26 Date rule based rollover from ESM4 to next contract occurs at 2014-06-12. | 2015-03-12 13:05:26 Date rule based rollover from ESU4 to next contract occurs at 2014-09-11. | 2015-03-12 13:05:26 Date rule based rollover from ESZ4 to next contract occurs at 2014-12-11. | 2015-03-12 13:05:26 Date rule based rollover from ESH5 to next contract occurs at 2015-03-12. | 2015-03-12 13:05:26 Date rule based rollover from ESM5 to next contract occurs at 2015-06-11. | 2015-03-12 13:05:26 Checking Daily data file for symbol ESH4 for the date range from 2013-12-12 to 2014-03-13. | 2015-03-12 13:05:26 Checking Daily data file for symbol ESM4 for the date range from 2014-03-13 to 2014-06-12. | 2015-03-12 13:05:26 Checking Daily data file for symbol ESU4 for the date range from 2014-06-12 to 2014-09-11. | 2015-03-12 13:05:26 Checking Daily data file for symbol ESZ4 for the date range from 2014-09-11 to 2014-12-11. | 2015-03-12 13:05:26 Checking Daily data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:05:26 Checking Daily data file for symbol ESM5 for the date range from 2015-03-12 to 2015-03-12. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2 | Symbols used for continuous contract chart: | 2015-03-12 13:05:26 ESH4 | 2015-03-12 13:05:26 ESM4 | 2015-03-12 13:05:26 ESU4 | 2015-03-12 13:05:26 ESZ4 | 2015-03-12 13:05:26 ESH5 | 2015-03-12 13:05:26 ESM5 | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: ESH4 Open price on 2014-03-13 is 1868.75. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: ESM4 Open price on 2014-03-13 is 1861.5. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: ESH4 price difference to ESM4 is -7.25. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: ESM4 Open price on 2014-06-12 is 1943.75. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: ESU4 Open price on 2014-06-12 is 1936.75. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: ESM4 price difference to ESU4 is -7. | 2015-03-12 13:05:26 HD Request # 6 | Decompressing data. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: ESU4 Open price on 2014-09-11 is 1994.5. | 2015-03-12 13:05:26 HD Request # 6 | Receiving Intraday data for ESM5 starting at 2015-03-12 13:05:10 | 2015-03-12 13:05:26 HD Request # 6 | Timestamp of first Intraday data file record written: 2015-03-12 13:05:18 | 2015-03-12 13:05:26 Socket (7) | Shutdown and closed. | 2015-03-12 13:05:26 The network socket for historical data has been closed. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: ESZ4 Open price on 2014-09-11 is 1986.75. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: ESU4 price difference to ESZ4 is -7.75. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: ESZ4 Open price on 2014-12-11 is 2026.25. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: ESH5 Open price on 2014-12-11 is 2019.75. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: ESZ4 price difference to ESH5 is -6.5. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: ESH5 Open price on 2015-03-12 is 2042. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: ESM5 Open price on 2015-03-12 is 2034.75. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: ESH5 price difference to ESM5 is -7.25. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: Back adjust amount for symbol ESH4 is -35.75. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: Back adjust amount for symbol ESM4 is -28.5. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: Back adjust amount for symbol ESU4 is -21.5. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: Back adjust amount for symbol ESZ4 is -13.75. | 2015-03-12 13:05:26 ESM5 [CB] Daily #2: Back adjust amount for symbol ESH5 is -7.25. | 2015-03-12 13:05:26 HD Request # 6 | Received 37 records from 2015-03-12 13:05:10 to 2015-03-12 13:05:26 (16.0 seconds) and wrote 29 records for ESM5 | 2015-03-12 13:05:26 HD Request # 6 | Intraday download COMPLETE for ESM5. Completion time: 0s. Unique request ID: 5 | 2015-03-12 13:05:26 Removed historical data download ID 5 | 2015-03-12 13:05:26 Real-time Intraday chart data file updates started for ESM5 | 2015-03-12 13:05:26 HD Request # 7 | Downloading Intraday chart data for GCLJ5 to the file GCLJ5.scid. Service: oec | 2015-03-12 13:05:26 HD Request # 7 | Download start Date-Time: 2015-03-12 13:05:12.0 | 2015-03-12 13:05:26 HD Request # 7 | Using server: oec.sierracharts.com port 10149 | 2015-03-12 13:05:26 Chart #3 has tagged chart #5 for full recalculation. Chartbook: IOAMT rebuild 10222014.cht | 2015-03-12 13:05:26 Socket (0) | Resolved address oec.sierracharts.com to IP 204.11.49.26 | 2015-03-12 13:05:26 Chart #5 is performing a full recalculation because it has been tagged. Chartbook: IOAMT rebuild 10222014.cht | 2015-03-12 13:05:26 Socket (8) | Connected. | 2015-03-12 13:05:26 HD Request # 7 | Sending historical data logon request message. | 2015-03-12 13:05:26 HD Request # 7 | Requesting Intraday data. Start Date-Time: 2015-03-12 13:05:12. Record interval: 0. Symbol: GCLJ5 | 2015-03-12 13:05:26 Open E Cry FIX | Starting real-time market data updates for: GGCJ5. ID: 4 | 2015-03-12 13:05:26 Open E Cry FIX | Starting real-time market data updates for: ZBM5. ID: 5 | 2015-03-12 13:05:26 HD Request # 7 | Decompressing data. | 2015-03-12 13:05:26 HD Request # 7 | Receiving Intraday data for GCLJ5 starting at 2015-03-12 13:05:12 | 2015-03-12 13:05:26 HD Request # 7 | Timestamp of first Intraday data file record written: 2015-03-12 13:05:12 | 2015-03-12 13:05:26 Socket (8) | Shutdown and closed. | 2015-03-12 13:05:26 The network socket for historical data has been closed. | 2015-03-12 13:05:26 HD Request # 7 | Received 254 records from 2015-03-12 13:05:12 to 2015-03-12 13:05:27 (15.0 seconds) and wrote 250 records for GCLJ5 | 2015-03-12 13:05:28 HD Request # 7 | Intraday download COMPLETE for GCLJ5. Completion time: 2s. Unique request ID: 6 | 2015-03-12 13:05:28 Removed historical data download ID 6 | 2015-03-12 13:05:28 Real-time Intraday chart data file updates started for GCLJ5 | 2015-03-12 13:05:28 HD Request # 8 | Downloading Intraday chart data for RLM-MM5 to the file RLM-MM5.scid. Service: oec | 2015-03-12 13:05:28 HD Request # 8 | Download start Date-Time: 2015-03-12 13:05:09.0 | 2015-03-12 13:05:28 HD Request # 8 | Using server: oec.sierracharts.com port 10149 | 2015-03-12 13:05:28 Socket (0) | Resolved address oec.sierracharts.com to IP 204.11.49.26 | 2015-03-12 13:05:28 Socket (9) | Connected. | 2015-03-12 13:05:28 HD Request # 8 | Sending historical data logon request message. | 2015-03-12 13:05:28 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2015-03-12 13:05:09. Record interval: 0. Symbol: RLM-MM5 | 2015-03-12 13:05:28 HD Request # 8 | Decompressing data. | 2015-03-12 13:05:28 HD Request # 8 | Receiving Intraday data for RLM-MM5 starting at 2015-03-12 13:05:09 | 2015-03-12 13:05:28 HD Request # 8 | Timestamp of first Intraday data file record written: 2015-03-12 13:05:18 | 2015-03-12 13:05:28 Socket (9) | Shutdown and closed. | 2015-03-12 13:05:28 The network socket for historical data has been closed. | 2015-03-12 13:05:28 HD Request # 8 | Received 3 records from 2015-03-12 13:05:09 to 2015-03-12 13:05:18 (9.0 seconds) and wrote 2 records for RLM-MM5 | 2015-03-12 13:05:28 HD Request # 8 | Intraday download COMPLETE for RLM-MM5. Completion time: 0s. Unique request ID: 7 | 2015-03-12 13:05:28 Removed historical data download ID 7 | 2015-03-12 13:05:28 Real-time Intraday chart data file updates started for RLM-MM5 | 2015-03-12 13:05:28 Requesting market depth updates for: ESM5 if supported. | 2015-03-12 13:05:30 Open E Cry FIX: Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2015-03-12 13:05:40 Date rule based rollover from GCLH5 to next contract occurs at 2015-02-19. | 2015-03-12 13:07:17 Date rule based rollover from GCLJ5 to next contract occurs at 2015-03-19. | 2015-03-12 13:07:17 Checking Intraday data file for symbol GCLH5 for the date range from 2015-01-19 to 2015-02-19. | 2015-03-12 13:07:17 Checking Daily data file for symbol GCLH5 for the date range from 2015-01-19 to 2015-02-19. | 2015-03-12 13:07:17 Checking Intraday data file for symbol GCLJ5 for the date range from 2015-02-19 to 0. | 2015-03-12 13:07:17 Checking Daily data file for symbol GCLJ5 for the date range from 2015-02-19 to 2015-03-12. | 2015-03-12 13:07:17 GCLJ5 [CB] 220 Trades #1 | Symbols used for continuous contract chart: | 2015-03-12 13:07:17 GCLH5 | 2015-03-12 13:07:17 GCLJ5 | 2015-03-12 13:07:17 GCLJ5 [CB] 220 Trades #1: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:07:17 GCLJ5 [CB] 220 Trades #1: GCLH5 Open price on 2015-02-19 is 50.55. | 2015-03-12 13:07:17 GCLJ5 [CB] 220 Trades #1: GCLJ5 Open price on 2015-02-19 is 51.25. | 2015-03-12 13:07:17 GCLJ5 [CB] 220 Trades #1: GCLH5 price difference to GCLJ5 is 0.69999999. | 2015-03-12 13:07:17 GCLJ5 [CB] 220 Trades #1: Back adjust amount for symbol GCLH5 is 0.69999999. | 2015-03-12 13:07:17 Date rule based rollover from GCLH5 to next contract occurs at 2015-02-19. | 2015-03-12 13:07:17 Date rule based rollover from GCLJ5 to next contract occurs at 2015-03-19. | 2015-03-12 13:07:17 Checking Intraday data file for symbol GCLH5 for the date range from 2015-01-19 to 2015-02-19. | 2015-03-12 13:07:17 Checking Daily data file for symbol GCLH5 for the date range from 2015-01-19 to 2015-02-19. | 2015-03-12 13:07:17 Checking Intraday data file for symbol GCLJ5 for the date range from 2015-02-19 to 0. | 2015-03-12 13:07:17 Checking Daily data file for symbol GCLJ5 for the date range from 2015-02-19 to 2015-03-12. | 2015-03-12 13:07:17 GCLJ5 [CB] 880 Trades #4 | Symbols used for continuous contract chart: | 2015-03-12 13:07:17 GCLH5 | 2015-03-12 13:07:17 GCLJ5 | 2015-03-12 13:07:17 GCLJ5 [CB] 880 Trades #4: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:07:17 GCLJ5 [CB] 880 Trades #4: GCLH5 Open price on 2015-02-19 is 50.55. | 2015-03-12 13:07:17 GCLJ5 [CB] 880 Trades #4: GCLJ5 Open price on 2015-02-19 is 51.25. | 2015-03-12 13:07:17 GCLJ5 [CB] 880 Trades #4: GCLH5 price difference to GCLJ5 is 0.69999999. | 2015-03-12 13:07:17 GCLJ5 [CB] 880 Trades #4: Back adjust amount for symbol GCLH5 is 0.69999999. | 2015-03-12 13:07:17 Date rule based rollover from GCLH5 to next contract occurs at 2015-02-19. | 2015-03-12 13:07:18 Date rule based rollover from GCLJ5 to next contract occurs at 2015-03-19. | 2015-03-12 13:07:18 Checking Intraday data file for symbol GCLH5 for the date range from 2015-01-19 to 2015-02-19. | 2015-03-12 13:07:18 Checking Daily data file for symbol GCLH5 for the date range from 2015-01-19 to 2015-02-19. | 2015-03-12 13:07:18 Checking Intraday data file for symbol GCLJ5 for the date range from 2015-02-19 to 0. | 2015-03-12 13:07:18 Checking Daily data file for symbol GCLJ5 for the date range from 2015-02-19 to 2015-03-12. | 2015-03-12 13:07:18 GCLJ5 [CB] 500 Trades #2 | Symbols used for continuous contract chart: | 2015-03-12 13:07:18 GCLH5 | 2015-03-12 13:07:18 GCLJ5 | 2015-03-12 13:07:18 GCLJ5 [CB] 500 Trades #2: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:07:18 GCLJ5 [CB] 500 Trades #2: GCLH5 Open price on 2015-02-19 is 50.55. | 2015-03-12 13:07:18 GCLJ5 [CB] 500 Trades #2: GCLJ5 Open price on 2015-02-19 is 51.25. | 2015-03-12 13:07:18 GCLJ5 [CB] 500 Trades #2: GCLH5 price difference to GCLJ5 is 0.69999999. | 2015-03-12 13:07:18 GCLJ5 [CB] 500 Trades #2: Back adjust amount for symbol GCLH5 is 0.69999999. | 2015-03-12 13:07:18 Open E Cry FIX: Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2015-03-12 13:25:29 Date rule based rollover from RLM-MH5 to next contract occurs at 2015-03-12. | 2015-03-12 13:25:50 Date rule based rollover from RLM-MM5 to next contract occurs at 2015-06-11. | 2015-03-12 13:25:50 Checking Intraday data file for symbol RLM-MH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:25:50 Checking Daily data file for symbol RLM-MH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:25:50 Checking Intraday data file for symbol RLM-MM5 for the date range from 2015-03-12 to 0. | 2015-03-12 13:25:50 Checking Daily data file for symbol RLM-MM5 for the date range from 2015-03-12 to 2015-03-12. | 2015-03-12 13:25:50 RLM-MM5 [CB] 220 Trades #1 | Symbols used for continuous contract chart: | 2015-03-12 13:25:50 RLM-MH5 | 2015-03-12 13:25:50 RLM-MM5 | 2015-03-12 13:25:50 RLM-MM5 [CB] 220 Trades #1: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:25:50 RLM-MM5 [CB] 220 Trades #1: RLM-MH5 Open price on 2015-03-12 is 1216.9. | 2015-03-12 13:25:50 RLM-MM5 [CB] 220 Trades #1: RLM-MM5 Open price on 2015-03-12 is 1211.6. | 2015-03-12 13:25:50 RLM-MM5 [CB] 220 Trades #1: RLM-MH5 price difference to RLM-MM5 is -5.3000002. | 2015-03-12 13:25:50 RLM-MM5 [CB] 220 Trades #1: Back adjust amount for symbol RLM-MH5 is -5.3000002. | 2015-03-12 13:25:50 Date rule based rollover from RLM-MH5 to next contract occurs at 2015-03-12. | 2015-03-12 13:25:50 Date rule based rollover from RLM-MM5 to next contract occurs at 2015-06-11. | 2015-03-12 13:25:50 Checking Intraday data file for symbol RLM-MH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:25:50 Checking Daily data file for symbol RLM-MH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:25:50 Checking Intraday data file for symbol RLM-MM5 for the date range from 2015-03-12 to 0. | 2015-03-12 13:25:50 Checking Daily data file for symbol RLM-MM5 for the date range from 2015-03-12 to 2015-03-12. | 2015-03-12 13:25:50 RLM-MM5 [CB] 880 Trades #4 | Symbols used for continuous contract chart: | 2015-03-12 13:25:50 RLM-MH5 | 2015-03-12 13:25:50 RLM-MM5 | 2015-03-12 13:25:50 RLM-MM5 [CB] 880 Trades #4: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:25:50 RLM-MM5 [CB] 880 Trades #4: RLM-MH5 Open price on 2015-03-12 is 1216.9. | 2015-03-12 13:25:50 RLM-MM5 [CB] 880 Trades #4: RLM-MM5 Open price on 2015-03-12 is 1211.6. | 2015-03-12 13:25:50 RLM-MM5 [CB] 880 Trades #4: RLM-MH5 price difference to RLM-MM5 is -5.3000002. | 2015-03-12 13:25:50 RLM-MM5 [CB] 880 Trades #4: Back adjust amount for symbol RLM-MH5 is -5.3000002. | 2015-03-12 13:25:50 Date rule based rollover from RLM-MH5 to next contract occurs at 2015-03-12. | 2015-03-12 13:25:50 Date rule based rollover from RLM-MM5 to next contract occurs at 2015-06-11. | 2015-03-12 13:25:50 Checking Intraday data file for symbol RLM-MH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:25:50 Checking Daily data file for symbol RLM-MH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-03-12 13:25:50 Checking Intraday data file for symbol RLM-MM5 for the date range from 2015-03-12 to 0. | 2015-03-12 13:25:50 Checking Daily data file for symbol RLM-MM5 for the date range from 2015-03-12 to 2015-03-12. | 2015-03-12 13:25:50 RLM-MM5 [CB] 500 Trades #2 | Symbols used for continuous contract chart: | 2015-03-12 13:25:50 RLM-MH5 | 2015-03-12 13:25:50 RLM-MM5 | 2015-03-12 13:25:50 RLM-MM5 [CB] 500 Trades #2: Performing continuous futures contract back adjustment calculations. | 2015-03-12 13:25:50 RLM-MM5 [CB] 500 Trades #2: RLM-MH5 Open price on 2015-03-12 is 1216.9. | 2015-03-12 13:25:50 RLM-MM5 [CB] 500 Trades #2: RLM-MM5 Open price on 2015-03-12 is 1211.6. | 2015-03-12 13:25:50 RLM-MM5 [CB] 500 Trades #2: RLM-MH5 price difference to RLM-MM5 is -5.3000002. | 2015-03-12 13:25:50 RLM-MM5 [CB] 500 Trades #2: Back adjust amount for symbol RLM-MH5 is -5.3000002. | 2015-03-12 13:25:50 Thanks again. |
| [2015-03-12 18:46:27] |
We do not see any market data reject message from OEC for this symbol. Nevertheless, try reconnecting by selecting File >> Disconnect and File >> Connect to Data Feed. If you are still not receiving data, refer to help topic 3.4: https://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.4 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
