Date/Time: Thu, 17 Sep 2026 04:09:27 +0000
Name of the Data Provider
View Count: 1107
| [2015-03-12 12:35:03] |
| GmA - Posts: 20 |
Hello Support Board! Is there any function/variable in ASCIL what could provide the name of the broker (Data provider (like TransAct)) connected to the Sierrachart? Thanks in aadvance and Kind regards GmA |
| [2015-03-12 18:59:38] |
No there is not. However, we could add this. Is it critical to have?
| [2015-03-12 19:29:12] |
| GmA - Posts: 20 |
Thank you for the fast response. It is important for my studies and if you can add it, that can be very good. |
| [2015-03-13 03:46:36] |
OK we will see about adding this to the next release.
| [2015-03-13 05:56:30] |
| GmA - Posts: 20 |
Thank you very much
