Date/Time: Thu, 17 Sep 2026 04:09:08 +0000
Time Line Study - restricted to 100 on Price scale?
View Count: 1105
| [2015-03-12 09:23:39] |
| Trint - Posts: 115 |
The Time Line Study only goes to 100 for Price when the scale is set as 'Same As Region' or 'Independent'
| [2015-03-12 20:05:20] |
If you need different requirements, you can modify the study. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
