Date/Time: Thu, 17 Sep 2026 04:09:18 +0000
Errant/Expired symbols loading on SC Startup
View Count: 1200
| [2015-03-11 18:03:18] |
| NRGTrader - Posts: 351 |
Version 1235; DataFeed OEC Checking my message log, there are several errant futures symbols "loading" on startup. I've scanned through all my charts to be sure all of my chart drawings are using the current symbol of the data file. I've restarted and still these apparently attempt to load. One of which creates a data file, but it obviously isn't being used since I can delete that data file while SC chart is open and running. Those being used can not be deleted while SC is running. How can I determine what is causing these bogus symbols to load? Is there a quick way to determine this? |
| [2015-03-13 07:58:02] |
Refer to this section here: http://www.sierrachart.com/index.php?page=doc/doc_ChartDataFiles.html#CleaningUpOldSymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
