Date/Time: Mon, 14 Sep 2026 03:21:58 +0000
Point and Figure Charts since v1224
View Count: 1537
| [2015-03-11 08:26:23] |
| KinsaleForex - Posts: 19 |
Hi, I've been using a custom point and figure study for the past couple of years. I've been using v1224 for the majority of this year and decided to update this morning to v1239. Somewhere between these two releases the custom study now doesn't work properly. I'm presuming something to do with the change in v1226. I've tried recompiling the study and this isn't working either. In the screenshot i'm using a 1pip box size with a 3 box reversal yet the chart is printing boxes for every 0.5 pips and I can't figure out why. I'll have to go back to v1224 for now as this is the last time I know it worked properly. Any suggestions? |
| [2015-03-11 09:13:07] |
We think we have an idea why this is happening and we will look into it later today.
| [2015-03-12 04:10:43] |
We have determined the problem is because you are using a custom point and figure study. This problem will be solved in the next release coming out tomorrow.
