Date/Time: Sun, 20 Sep 2026 15:31:43 +0000
1 bar per session
View Count: 1961
| [2015-03-10 19:18:46] |
| jivetrader - Posts: 410 |
using Intraday charts with 1 day periodicity, with non-overlapping session times set, and with New Bar at Session Start & Use Evening Session both checked, how do i get a chart to show 1 bar per session? i am seeing 1 bar per day.
| [2015-03-10 19:39:57] |
You need to figure it out if it is possible. It is not obvious to us.
| [2015-03-10 20:59:48] |
| Sawtooth - Posts: 4354 |
Set the bar time to the sum of the two sessions
| [2015-03-10 21:46:11] |
tom, i'm not sure i understand. currently seeing 1 bar per day. i want to split this to see 1 bar per session (2 bars per day). |
| [2015-03-10 22:21:09] |
Using your settings from post #1, sum the duration of each session in minutes and set the Bar Period like this: 0-1330-0. This will produce 2 bars per day, one for each session. This only works if the sum is less than 1440, and bars are time-based. |
