Date/Time: Sat, 19 Sep 2026 06:57:54 +0000
Fib indicator
View Count: 1502
| [2015-03-10 19:09:12] |
| Adam - Posts: 141 |
i have finally found and set up all the indicators i need apart from one. to plot the previous days Fib levels and the current days fib levels. attached is it working in NT, is there an Equiv in SC? Thanks |
| [2015-03-10 19:38:33] |
The closest Sierra Chart has is the Auto Retracement/Projection study.
