Date/Time: Mon, 14 Sep 2026 19:48:49 +0000
Time Alerts Changed on DST Time Change
View Count: 1296
| [2015-03-10 18:18:16] |
| Futures Operator - Posts: 239 |
Just FYI: After the DST time change and correct new computer time update, the Time Alerts saved in SC v1220 have all changed to be 1 hour later than they were originally set to.
Date Time Of Last Edit: 2015-03-10 18:57:28
| [2015-03-10 19:30:51] |
We will check on this.
| [2015-03-11 13:56:09] |
| Al SC Developer - Posts: 434 |
This has been addressed in next release.
