Date/Time: Sun, 22 Nov 2026 01:52:14 +0000
Symbol $TYX
View Count: 2651
| [2015-03-06 21:16:12] |
| NRGTrader - Posts: 351 |
My chart for $TYX won't update data beyond Sept of last year. I searched but don't see a different symbol for 30-year TBond Yield. Anyone else having this issue?
| [2015-03-07 00:39:31] |
Refer to this section here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#AccessCashIndexMarketData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-03-07 15:55:53] |
I'm confused. My DAILY historical data for other indices, e.g., $TNX, $INX are updated fine through yesterday, March 06, 2015. Why isn't $TYX?
| [2015-03-07 19:39:23] |
The chart is up-to-date for us: http://www.sierrachart.com/image.php?l=1425757133756.png Therefore, open a new chart for this symbol or refer to help topic 6: Http://www.sierrachart.com/index.php?page=doc/helpdetails6.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-03-08 17:16:41] |
Very bizarre. I found one other symbol with same issue, $FVX. Odd since $TNX has been updating fine. For those two symbols I tried new chart - same problem. Tried, delete download and no update. I disconnected, cut and paste the each file from my data directory to another folder, essentially deleting the data files. I then reconnected and voila, both charts updated AND have the same date starting point as the original files (i.e., no issue with a data limit). Oh well, works now, or at least updated. We shall see this week. |
| [2015-03-08 18:48:18] |
Before deleting the data files, did you try selecting Edit >> Delete All Data and Download.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-08 18:48:26
| [2015-03-09 13:33:59] |
my comment, "Tried, delete download and no update" was for Edit >> Delete and Download Data. I chose from about mid-year 2014. I did not want to delete and download all.
