Date/Time: Tue, 20 Oct 2026 12:36:31 +0000
TWO COMPUTERS
View Count: 1266
| [2015-03-02 14:52:25] |
| User57072 - Posts: 49 |
I HAVE 2 DIFFERENT LOCATIONS, AND TRAVEL BACK AND FORTH. WHEN I WORK ON SC AT ONE PLACE IT DOES NOT SHOW UP THE SAME AT THE OTHER HOUSE. HOW CAN I GET BOTH PLACES TO SYNC ?
| [2015-03-02 16:22:40] |
Sierra Chart stores its settings on the local computer. You will need to manually copy over the settings and Chartbook Files between the two installations. For more information on which files need to be copied, refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Do note that help topic 15, is not optimized for your particular situation but for transferring the settings from one computer onto another one. Sierra Chart Support Date Time Of Last Edit: 2015-03-02 18:36:03
| [2015-03-02 17:27:42] |
OK,What about transferring some charts from the source to be replaced, into the new source ?
| [2015-03-02 18:37:14] |
Charts are part of Chartbooks, so you need to copy the Chartbooks you want to transfer. Refer to this section here for help with this: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#CopyChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
