Date/Time: Tue, 20 Oct 2026 12:36:31 +0000
Range Bars and Volume by Price Issue
View Count: 1306
| [2015-03-01 22:19:12] |
| Johnny - Posts: 99 |
I have noticed many discrepancies in volume profiles between the Fill Gaps and Open=Close Range bar types even though the bars have the same timestamp and the exact same volume. |
| [2015-03-01 22:34:48] |
Differences should be expected and are correct. Based on the information given so far we will not spend time looking into this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-01 22:35:16
