Date/Time: Mon, 05 Oct 2026 19:48:01 +0000
Alert Enabled on all new studies
View Count: 1235
| [2015-02-27 02:42:31] |
| MKL17 - Posts: 35 |
I have somehow enabled something that now sets each new study with one of the alerts I created previously. So, when I add it I have to go into the alerts tab on the settings and uncheck it but how can I remove this setting? I have tried to find a solution but don't know what I pressed. Thx.
| [2015-02-27 02:55:59] |
Refer to: Chart Studies: Using Custom Default Study Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-02-27 03:56:35] |
| MKL17 - Posts: 35 |
I think my case is slightly different. Somehow this alert is now enabled on all studies. I have tested this on studies I have never used before and when I go the alerts section the alert is enabled so my question is is there a global setting that I enabled that caused all these studies to default to having this alert checked? Thx.
| [2015-02-27 04:48:41] |
If you are merely referring to the "Alert Enabled" option in Study Settings, this by default is on and does not mean anything if there is no alert condition formula defined. It should always be on. It is a rare case for it to be off.
