Date/Time: Wed, 16 Sep 2026 20:21:19 +0000
draw style value on high
View Count: 1471
| [2015-02-26 23:57:35] |
| User53474 - Posts: 19 |
In a spreadsheet study for trading, I am displaying values in column R on the region 1 chart with the Draw Style set to Value On High in the settings and inputs for the spreadsheet study. Is there a way to control the format of the number displayed? Now it displays with 2 decimal places. I would like to have the value displayed with just 1 decimal place or with no decimal places at all. I tried formatting the column in the spreadsheet to have 1 decimal place and I am rounding the formula there to 1 decimal place but it still displays with 2 places on the chart, the 2nd position always a zero.
| [2015-02-27 00:06:37] |
You need to change the Value Format setting in the Study Settings window for the Spreadsheet study.
