Date/Time: Sat, 07 Nov 2026 12:56:53 +0000
[User Discussion] - "Reverse Position" in the Trading Window
View Count: 2443
| [2015-02-26 16:06:48] |
| User22414 - Posts: 68 |
I have much pleasure in the trading functions directly out of the Chart (Targets: Stop 1 /4T/Qty 1/Stop). Unfortunately, much is deceived by the major players in the BUND and thus cheated fall into the wrong direction provided, so you have when you sit in the fall quickly rotate the Position. My question is how could I have an additional button in the window with the funtion: "reverse position"? How can I set up, please step by step description Thank you and best regards Helmut |
| [2015-02-26 19:27:08] |
There is already a Reverse command on the Trade Window. It is documented here: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#ReverseCxl Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-02-26 22:01:15] |
Thanks, but It's too hard for me to configure all this. Also, not least because my English is poor and the German translation mind twisted part. I can not send my chart and get back the setting. If it does not cost too much, I can pay something for it.
| [2015-02-26 22:04:26] |
...the same applies to my problem with the formulas in the NEW SPREDSHEETS
| [2015-02-27 00:22:51] |
"Reverse" is a button on the Trade Window. There is nothing to configure. Maybe it is disabled: Basic Trading and the Trade Window: Enabling/Disabling Trade Window Order Buttons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-02-27 13:51:57] |
I can not adjust. I come only to the extent that a new symol "@ 1" appears, but it can not be moved. In the General Settings -> Data Files Folder, windows I can select anything. Can I not get someone from the support, where appropriate, may also help someone also access my comuter and set it in front of my eyes. |
