Date/Time: Tue, 22 Sep 2026 01:54:30 +0000
number bar chart value error
View Count: 1346
[2015-02-24 20:38:09]
User99934 - Posts: 227
It looks like the chart value in ASK column is being truncated a digit.
Private File
[2015-02-24 23:54:19]
This really is impossible for us to comment on. We do not know if Volume Filtering has been set on the chart or what the value should be.
Just make sure you have a tick by tick data configuration:
Do not use any volume filtering:
https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#VolumeFilterH
[2015-02-25 04:14:39]
I double checked your suggestions. If you look at the screenshot you will set that not enough text spaces have been allocated to display the number correctly. You can see the calculator value is the same as the AV value except the additional digits are not displayed.
[2015-02-25 04:20:52]
There is insufficient information for us to comment on this. There is no problem with the Numbers Bars. There could not be.
[2015-02-25 04:27:44]
its not in the number bar, its in the display above it. Please look at picture in the areas I underlined in red in this reply.
imageScreenshot - 2_24_2015 , 3_32_57 PM.jpg / V - Attached On 2015-02-25 04:26:32 UTC - Size: 34.93 KB - 611 views
[2015-02-25 18:55:54]
That particular status bar is limited and going to be removed soon. We no longer provide support for it. Please do not rely on it. Use what is described here:
Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools
