Date/Time: Mon, 29 Apr 2024 15:21:48 +0000
[User Discussion] - Custom Market Profile Chart
View Count: 20264
[2018-08-07 21:36:39] |
WarriorTrader - Posts: 245 |
Here is the Custom Profile reposted. It is compiled in SC version 1729 64 bit (CustomProfile_U_64.dll) and the older 32 bit (CustomProfile_U.dll). It will work on any SC version 1729 and up. Sample chartbooks are also included in continuation post below this one.
CustomProfile_Letters.png / V - Attached On 2018-08-07 21:19:45 UTC - Size: 91.59 KB - 580 views CustomProfile_Block.png / V - Attached On 2018-08-07 21:20:02 UTC - Size: 60.88 KB - 544 views CustomProfile_U_64.dll - Attached On 2018-08-07 21:31:48 UTC - Size: 129.5 KB - 501 views |
[2018-08-07 21:39:35] |
Continuation.. Sample chartbooks in next post. |
CustomProfileFillSpace_64.dll - Attached On 2018-08-07 21:37:28 UTC - Size: 95.5 KB - 488 views CustomProfile_U.dll - Attached On 2018-08-07 21:37:53 UTC - Size: 114.5 KB - 494 views CustomProfileFillSpace.dll - Attached On 2018-08-07 21:38:17 UTC - Size: 80.5 KB - 511 views |
[2018-08-07 21:41:11] |
Sample chartbooks....
CustomProfileExample1.Cht - Attached On 2018-08-07 21:40:37 UTC - Size: 75.09 KB - 557 views CustomProfileExample2.Cht - Attached On 2018-08-07 21:40:53 UTC - Size: 65.79 KB - 562 views |
[2018-08-07 23:06:40] |
marty_nv - Posts: 85 |
WT, Thanks for the downloads. The charts are now visible on my machine. It is too late to work with them today. But they will provide for some interesting experimentation. Marty |
[2018-08-08 20:10:52] |
Hi WT, Attached is a png of your CustomProfileExample2. In looking at the study dialog box (bottom of attachment), I can't seem to locate the adjustment to make the charts look like you png's of post #75 above. Any suggestions would be appreciated. Marty |
PAT 180808-1 CustomProfileExample2.png / V - Attached On 2018-08-08 20:09:18 UTC - Size: 240.01 KB - 619 views Attachment Deleted. |
[2019-05-09 04:36:13] |
Hello All, Here is an updated version that finds the overnight range correctly if you are using Asian market hours. Compiled in SC version 1729. It should work with any later version. Dll's on next post. Date Time Of Last Edit: 2019-05-09 04:51:48
CustomProfile_Letters.png / V - Attached On 2019-05-09 04:51:16 UTC - Size: 91.59 KB - 399 views CustomProfile_Block.png / V - Attached On 2019-05-09 04:51:40 UTC - Size: 60.88 KB - 393 views |
[2019-05-09 04:43:26] |
Here are the DLL's Use the example chartbooks in post #77 Custom Market Profile Chart | Post: 154058 |
CustomProfile_U_64.dll - Attached On 2019-05-09 04:40:22 UTC - Size: 129.5 KB - 375 views CustomProfileFillSpace_64.dll - Attached On 2019-05-09 04:41:11 UTC - Size: 95.5 KB - 378 views |
[2019-05-09 05:28:36] |
Dom7364 - Posts: 257 |
This is great but still can't get it to work. Here is what I do: 1. Open a daily chart 2. Add both studies 3. Display studies on another daily plain chart 4. Nothing happens Clearly doing tomething wrong here... But what? Cheers |
[2019-05-10 06:26:59] |
WarriorTrader2 - Posts: 3 |
This is great but still can't get it to work. Here is what I do: 1. Open a daily chart You have to use an intraday chart. How do you get market profile to work on a daily chart? Thx, WT PS: posting this from my Amp Futures account - this is WarriorTrader Date Time Of Last Edit: 2019-05-10 06:29:19
[2019-05-10 06:30:00] |
Hi WT, It is intraday not daily yes. Txs |
[2019-05-10 06:46:45] |
Hi WT,
It is intraday not daily yes. Txs Try the two sample chartbooks included above. If those don't work, I'll have to compile the study in the current SC version over the weekend. Thx, -WT |
[2019-05-11 11:02:35] |
Hi WT, it does not work for me in 1916 no.. Cheers |
[2019-05-20 05:31:03] |
He Here is the SC 1919 version. Use the example chartbooks in post #77 Custom Market Profile Chart | Post: 154058 Thx, --WT Date Time Of Last Edit: 2019-05-20 05:39:43
CustomProfile_U_64.dll - Attached On 2019-05-20 05:29:52 UTC - Size: 139 KB - 451 views CustomProfileFillSpace_64.dll - Attached On 2019-05-20 05:34:44 UTC - Size: 95.5 KB - 444 views CustomProfile_Letters.png / V - Attached On 2019-05-20 05:39:26 UTC - Size: 91.01 KB - 616 views |
[2019-05-20 05:42:24] |
Her is the picture for blocks.
CustomProfile_Block.png / V - Attached On 2019-05-20 05:42:03 UTC - Size: 57.05 KB - 646 views |
[2019-10-21 03:20:25] |
User120942 - Posts: 71 |
@WarriorTrader, I have been using your most recent study but have been having two issues: 1. The Profile in the Fill Space on my charge has gaps in the profile that are moving the TPO to the right. (see images attached) 2. When the chart is refreshed the historical TPOs disappear from the chart. I have to remove the study and add it back to the chart for them to reappear. I am currently on Sierra Chart version # 2000 and was inquiring if you have an updated version of the study that resolves the issues listed above? Or if it may be the settings that are not configured correctly? Thank You |
2019-10-20 23_07_19-Sierra Chart Custom Profile Study.png / V - Attached On 2019-10-21 03:18:56 UTC - Size: 154.63 KB - 452 views 2019-10-20 23_05_26-Study Settings_ Custom Profile. ID_1.png / V - Attached On 2019-10-21 03:19:04 UTC - Size: 37.37 KB - 458 views |
[2019-10-21 03:58:00] |
DogBone01 - Posts: 14 |
Hello. I have not been able to trade in a while, and have suspended my subscription. The best I can offer at this time is that it is in the settings. I recall spending hours & hours going thru several settings pages, over and over, trying to fix issues. Never quit. |
[2019-10-21 04:31:00] |
2. When the chart is refreshed the historical TPOs disappear from the chart. I have to remove the study and add it back to the chart for them to reappear. 1. I do not quite understand the problem. You will have to explain it better. Did you try to set the "Reset Profile" to yes to refresh the study? 2. Again, setting the "Reset Profile" to yes could redraw the historical profiles. I have not updated the study in a while. It is long past due. Did the example chartbook in post #77 help? Make sure your start date and overnight start date make sense. The study gets its times from those two fields. Custom Market Profile Chart | Post: 154058 Post some more examples so I can understand your issue. It probably has something to do with how the over night time period. The study has been around for a while - once I find the error it will be fixed quickly. Good Luck, -WT |
[2019-11-19 05:37:35] |
@WarriorTrader, I took some time to test the settings of the custom Profile version 1919. I am currently on Sierra Chart version 2012. I have attached screenshots of the Chart Settings, Custom Profile Settings and how the study appears on the destination NQZ9 TPO chart. It has been quite awhile since version 1919 and I believe the study is in need of an update to display correctly on the chart. It's a very useful study that i hope can be updated to correct the display issues that I am experiencing. Thank You |
Custom Profile Settings.png / V - Attached On 2019-11-19 05:32:56 UTC - Size: 427.77 KB - 511 views |
[2019-11-24 08:42:13] |
Hello, I will work on it this week and get it out as soon as I can. --WT |
[2020-02-26 07:08:09] |
Hello, I have fixed some bugs and compiled the study in SC Version 2017. It should run fine on newer versions. I have included two example chartbooks. Just set the symbol to match your data feed. Date Time Of Last Edit: 2020-02-26 07:10:27
CustomProfile_U_64.dll - Attached On 2020-02-26 07:06:57 UTC - Size: 139 KB - 388 views CustomProfileFillSpace_64.dll - Attached On 2020-02-26 07:07:45 UTC - Size: 95.5 KB - 362 views CustomProfileExample1.Cht - Attached On 2020-02-26 07:10:02 UTC - Size: 76.81 KB - 395 views |
[2020-02-26 07:15:41] |
Here is another example chart book and some screen shots. Good Trading, --WT Date Time Of Last Edit: 2020-02-26 07:17:41
CustomProfileExample2.Cht - Attached On 2020-02-26 07:12:42 UTC - Size: 67.51 KB - 387 views CustomProfile_Block.png / V - Attached On 2020-02-26 07:14:56 UTC - Size: 60.88 KB - 463 views |
[2020-02-26 07:16:44] |
File attached
CustomProfile_Letters.png / V - Attached On 2020-02-26 07:16:22 UTC - Size: 91.59 KB - 598 views |
[2020-04-03 08:59:29] |
Hello All, Here is a updated version that has a new setting: Price Increment in Ticks With all the volatility recently, displaying the custom profile on a remote chart can really put a strain on your CPU. Now you can reduce the CPU usage by increasing the value in this setting. If you set it to two (2) the study will only draw very other block or letter. Set it to four (4) and only ever fourth block or letter will be drawn. The opening price will still always be marked with a different color, just as before. All the profile information is stored as before, but not all the blocks or letters will be displayed if the Price Increment is greater than one(1). Good Trading, --WT Date Time Of Last Edit: 2020-04-03 09:06:39
CustomProfile_U_64.dll - Attached On 2020-04-03 08:53:30 UTC - Size: 140 KB - 529 views Attachment Deleted. CustomProfile_new_setting.png / V - Attached On 2020-04-03 09:06:32 UTC - Size: 88.56 KB - 308 views |
[2020-04-13 05:16:07] |
With all the volatility recently, displaying the custom profile on a remote chart can really put a strain on your CPU. Now you can reduce the CPU usage by increasing the value in this setting. If you set it to two (2) the study will only draw very other block or letter. Set it to four (4) and only ever fourth block or letter will be drawn. Hello, Here is a new version that leaves the current bar unaffected by the Price Increment setting. Only bars after the current bar will be affected. The current bar will not loose any data. SC version 2017 and above |
CustomProfile_new_setting.png / V - Attached On 2020-04-13 05:11:54 UTC - Size: 88.56 KB - 343 views CustomProfile_U_64.dll - Attached On 2020-04-13 05:12:44 UTC - Size: 140 KB - 285 views |
[2020-08-22 20:35:06] |
UserV-Werks - Posts: 4 |
Hi Warrior, Thanks for you're amazing work product. I really want to expand the MP TPOs. However, I'm using v2156 and I've received a message that the .dll needs to be recompliled for v2156. Can you help? If you need some compensation just let know. We'll figure something out. Thanks. |
[2020-08-23 08:13:41] |
Hello, Here is a version compiled for SC version 2115. That should be good enough. Let me know if you have any problems. Use the sample chartbooks in post #94 and #95: Custom Market Profile Chart | Post: 208385 Custom Market Profile Chart | Post: 208386 Letter Profile Example: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=36158 Block Profile Example: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=28515 Good Trading, -WT |
CustomProfile_U_64.dll - Attached On 2020-08-23 08:09:48 UTC - Size: 140 KB - 311 views CustomProfileFillSpace_64.dll - Attached On 2020-08-23 08:12:27 UTC - Size: 95.5 KB - 296 views |
