Date/Time: Wed, 04 Nov 2026 15:52:56 +0000
Custom Bar Period
View Count: 3194
| [2015-02-13 19:38:59] |
| User21113 - Posts: 63 |
Hi, I want to create a custom bar period. Select >> Global Settings >> Customize Keyboard Shortcuts >> Chart >> Bar Periods When the shortcut is assigned and then selected, the Chart Settings dialog appears. Is there a way create a keyboard shortcut for a custom bar period? |
| [2015-02-14 02:07:43] |
Refer to the documentation here about creating ToolBar buttons for custom chart bar periods: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeToolbar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-12 00:17:30] |
| nus1 - Posts: 39 |
But how do you assign keyboard shortcut to it?
| [2021-01-12 04:20:44] |
You can use the keyboard to change the chart bars period: Changing Chart Bars Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-12 13:23:58] |
| nus1 - Posts: 39 |
For those who stumble across this, u'll need autohotkey to do it in a single click. Paste this in autohotkey file(change key and time frame to your preference): F6:: send 610v send {ENTER} return |
