Date/Time: Sat, 07 Nov 2026 20:54:17 +0000
Chart Drawings
View Count: 1303
[2015-02-04 10:54:55]
User22153 - Posts: 46
Hello Support,
Is there a setting I can set for chart drawings. Say I have a chart that is linked to the Quoteboard, andI have several other charts open in the background.
Can I draw objects on the main chart that is linked to the quote board to show up on the charts that are in the background? Because I don't want to draw the objects on both charts because I need alerts.
[2015-02-04 11:55:25]
I have found the setting to copy the objects from the main chart to the backgrounds charts. However, when I set the alert on the main chart, it doesn't get transferred to the other chart, only the drawing.
Is there something I'm missing?
[2015-02-05 04:32:58]
Chart Drawing Alerts are not evaluated on copied drawings.
[2015-02-06 09:36:34]
Zdislav - Posts: 73
is it possible to copy a chart drawing to a specific chart region in the desired chart window? For example I have several charts with different symbols with "Extending rectangles" drawn on them. Now I would like to consolidate some of those chart windows into one chart window with the drawings copied as well. Thanks for your answer.
Z.
[2015-02-06 17:57:04]
No, this is not supported.
