Date/Time: Tue, 20 Oct 2026 12:35:16 +0000
range bars
View Count: 1640
[2015-02-04 05:28:08]
User28682 - Posts: 233
Notice the area circled in red on the chart. This is a 5 tick range bar chart for CL. How can a bar be 4 ticks??? The high was 52.40, low 52.36...and you can see it is one tick short of 5 with your eye.I have seen this twice before.
Tom
imagerange_bar.png / V - Attached On 2015-02-04 05:27:42 UTC - Size: 21.23 KB - 514 views
[2015-02-04 17:38:07]
We will make sure the documentation explains this but for now uncheck Chart >> Chart Settings >>New Bar at Session Start.
[2015-03-05 19:00:54]
User888876 - Posts: 33
Good day,
I use number bars of 8 ticks (8 tick range bars). But usually I get on the chart bars of 9-10ticks long. Would u advise me, where the problem is?
[2015-03-06 04:12:38]
Refer to this help topic:
Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent
