Date/Time: Tue, 13 Oct 2026 18:38:55 +0000
Auto Trading a Different Security than the one used in spreadsheet Calculations.
View Count: 1141
| [2015-02-01 22:50:13] |
| User87521 - Posts: 116 |
I have what I thought was a fairly simple question but I am just not finding an answer by searching for it. I have an auto trade system worked out. I usually trade SPY but it can work for any stock obviously. I would like to trade SPY options. Is it possible to use the signals generated in the trade spreadsheet and trade a different security than the one used in the signal generations. Can I chart SPY and trade SPY options? I have thought about having a couple sheets going and cross-linking the two to generate signals, but would prefer a better approach. Thanks for the help. I am just not seeing this. |
| [2015-02-02 00:19:57] |
This is possible. Set the Chart >> Chart Settings >> Trade and Current Quote Symbol to the options symbol for the chart that contains the automated trading system. This will cause the current Quote Data you see in Window >> Current Quote Window to use the option pricing but the chart bars will be based upon the underlying symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-02-02 14:02:08] |
Thank you very much.
