Date/Time: Tue, 13 Oct 2026 18:37:07 +0000
sc.GetPersistentInt
View Count: 2482
[2015-01-22 15:35:19]
QnReally - Posts: 188
You have announced changes to Persistent variables in v1225. Will the SCDateTimeMS be supported? Thanks.
[2015-01-22 18:01:13]
Wait for the documentation which we will have done today and it will explain this.
Date Time Of Last Edit: 2015-01-22 18:01:23
[2015-02-03 02:57:44]
If I upgrade from v1224 to a higher version, can I expect the code that worked under v1224 to compile without errors if I stick to the old style persistent variables? For example, I use
int& beginIndex = sc.PersistVars->i3;
beginIndex = 10;
Thanks.
[2015-02-03 03:48:58]
Yes.
Also the new Get/SetPersistent* ACSIL functions have now been documented.
