Date/Time: Thu, 24 Sep 2026 16:48:33 +0000
I'm looking for lme data for the metals copper, lead and zinc
View Count: 1999
| [2013-05-23 14:08:30] |
| AndyL - Posts: 119 |
eSignal would have LME data, apparently Sierrachart will have support for eSignal soon(tm).
| [2013-05-23 15:10:08] |
| TastyRisk - Posts: 119 |
CTS
| [2013-05-24 00:12:58] |
We recommend E-Signal and support for that is coming soon. And apparently according to post #3 CTS T4 supports this as well. For documentation for this, refer to: http://www.sierrachart.com/index.php?l=doc/CTS_T4.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
