Date/Time: Wed, 18 Nov 2026 09:17:02 +0000
Message Log
View Count: 1245
[2015-01-12 19:56:10]
User46092 - Posts: 17
Can you please check my message log and tell me if there is a problem with my chart setup. Why does it keep performing back adjusted calculations?
Software version: 1222 | 2015-01-12 13:58:28
Uses New Spreadsheets | 2015-01-12 13:58:28
Usage end date: 2015-03-28 | 2015-01-12 13:58:28
Enabled for: Advanced Features. | 2015-01-12 13:58:28
Enabled for: Advanced Features 2. | 2015-01-12 13:58:28
Enabled for: Sierra Chart Historical Data Service. | 2015-01-12 13:58:28
Allow Support for Sierra Chart Data Feeds is enabled. | 2015-01-12 13:58:28
Active service: Rithmic Trading | 2015-01-12 13:58:28
Data/Trade Service Settings automatically set. | 2015-01-12 13:58:28
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-01-12 13:58:28
2015-01-12 19:58:28 Local computer clock time | 2015-01-12 13:58:28
2015-01-12 18:58:28 GMT time | 2015-01-12 13:58:28
2015-01-12 13:58:28 Time zone adjusted time | 2015-01-12 13:58:28
Time difference to server time: 0 seconds. | 2015-01-12 13:58:28
Program path: C:\SierraChart\ | 2015-01-12 13:58:28
Data Files path: C:\SierraChart\Data\ | 2015-01-12 13:58:28
OS Version Number: 6.2 | 2015-01-12 13:58:28
Locale Information: C | 2015-01-12 13:58:28
Checking for new symbol settings for rim | 2015-01-12 13:58:28
HTTP connection to www.sierrachart.com:80 (0) | Resolved address www.sierrachart.com to IP 5.9.8.236 | 2015-01-12 13:58:28
HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-01-12 13:58:28
Symbol settings are up-to-date for rim | 2015-01-12 13:58:28
Files to Open on Start up | Opening file: OpenTrader_1.cht | 2015-01-12 13:58:31
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 13:58:31
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 13:58:31
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 13:58:31
ESH5-CME [CB] 30 Min #4 | Symbols used for continuous contract chart: | 2015-01-12 13:58:31
ESH5-CME | 2015-01-12 13:58:31
ESH5-CME [CB] 30 Min #4: Performing continuous futures contract back adjustment calculations. | 2015-01-12 13:58:31
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 13:58:31
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 13:58:31
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 13:58:31
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 13:58:31
ESZ4-CME | 2015-01-12 13:58:31
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 13:58:31
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 13:58:31
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 13:58:31
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 13:58:31
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 13:58:31
ESH5-CME [CB] 30 Min #15 | Symbols used for continuous contract chart: | 2015-01-12 13:58:31
ESH5-CME [CB] 30 Min #15: Performing continuous futures contract back adjustment calculations. | 2015-01-12 13:58:31
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2015-01-12 13:58:31
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-12 13:58:31
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-12 13:58:31
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2015-01-12 13:58:31
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-12 13:58:31
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-12 13:58:31
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-12 13:58:31
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-12 13:58:31
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-12 13:58:31
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2015-01-12 13:58:31
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2015-01-12. | 2015-01-12 13:58:31
Performing historical Daily data download for symbol ESZ14 starting at 0. | 2015-01-12 13:58:31
ESZ4-CME [CB] 120 Min #11 | Symbols used for continuous contract chart: | 2015-01-12 13:58:31
ESH4-CME | 2015-01-12 13:58:31
ESM4-CME | 2015-01-12 13:58:31
ESU4-CME | 2015-01-12 13:58:31
ESZ4-CME [CB] 120 Min #11 | Waiting for historical downloads to complete with the IDs: 1, | 2015-01-12 13:58:31
Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-12 13:58:31 *
Skipping Daily data download for symbol ESZ14 since download was already done in last 24 hours. | 2015-01-12 13:58:31
ESZ4-CME [CB] 30 Min #6 | Symbols used for continuous contract chart: | 2015-01-12 13:58:31
ESZ4-CME [CB] 30 Min #6: Performing continuous futures contract back adjustment calculations. | 2015-01-12 13:58:31
ESZ4-CME [CB] 30 Min #6: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2015-01-12 13:58:31
ESZ4-CME [CB] 30 Min #6: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2015-01-12 13:58:31
ESZ4-CME [CB] 30 Min #6: ESH4-CME price difference to ESM4-CME is -7.25. | 2015-01-12 13:58:31
ESZ4-CME [CB] 30 Min #6: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-12 13:58:31
ESZ4-CME [CB] 30 Min #6: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-12 13:58:31
ESZ4-CME [CB] 30 Min #6: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-12 13:58:31
ESZ4-CME [CB] 30 Min #6: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-12 13:58:31
ESZ4-CME [CB] 30 Min #6: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-12 13:58:31
ESZ4-CME [CB] 30 Min #6: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-12 13:58:31
ESZ4-CME [CB] 30 Min #6: Back adjust amount for symbol ESH4-CME is -22. | 2015-01-12 13:58:31
ESZ4-CME [CB] 30 Min #6: Back adjust amount for symbol ESM4-CME is -14.75. | 2015-01-12 13:58:31
ESZ4-CME [CB] 30 Min #6: Back adjust amount for symbol ESU4-CME is -7.75. | 2015-01-12 13:58:31
ESH5-CME [CB] 2 Min #17 | Symbols used for continuous contract chart: | 2015-01-12 13:58:31
ESH5-CME [CB] 2 Min #17: Performing continuous futures contract back adjustment calculations. | 2015-01-12 13:58:31
ESH5-CME [CB] 2 Min #17: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 13:58:31
ESH5-CME [CB] 2 Min #17: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 13:58:31
ESH5-CME [CB] 2 Min #17: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 13:58:31
ESH5-CME [CB] 2 Min #17: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 13:58:31
Date rule based rollover from TF FMZ0014!-NYBOT to next contract occurs at 2014-12-11. | 2015-01-12 13:58:32
Date rule based rollover from TF FMH0015!-NYBOT to next contract occurs at 2015-03-12. | 2015-01-12 13:58:32
Checking Intraday data file for symbol TF FMZ0014!-NYBOT for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 13:58:32
Checking Daily data file for symbol RJZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 13:58:32
Checking Intraday data file for symbol TF FMH0015!-NYBOT for the date range from 2014-12-11 to 0. | 2015-01-12 13:58:32
Checking Daily data file for symbol RJH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 13:58:32
TF FMH0015!-NYBOT [CB] 5 Min #12 | Symbols used for continuous contract chart: | 2015-01-12 13:58:32
TF FMZ0014!-NYBOT | 2015-01-12 13:58:32
TF FMH0015!-NYBOT | 2015-01-12 13:58:32
TF FMH0015!-NYBOT [CB] 5 Min #12: Performing continuous futures contract back adjustment calculations. | 2015-01-12 13:58:32
TF FMH0015!-NYBOT [CB] 5 Min #12: TF FMZ0014!-NYBOT Open price on 2014-12-11 is 1162.2. | 2015-01-12 13:58:32
TF FMH0015!-NYBOT [CB] 5 Min #12: TF FMH0015!-NYBOT Open price on 2014-12-11 is 1157.5. | 2015-01-12 13:58:32
TF FMH0015!-NYBOT [CB] 5 Min #12: TF FMZ0014!-NYBOT price difference to TF FMH0015!-NYBOT is -4.6999998. | 2015-01-12 13:58:32
TF FMH0015!-NYBOT [CB] 5 Min #12: Back adjust amount for symbol TF FMZ0014!-NYBOT is -4.6999998. | 2015-01-12 13:58:32
HD Request # 2 | Downloading Historical Daily chart data for ESZ14. Starting date: 2014-12-18. Service: rim | 2015-01-12 13:58:33
HD Request # 2 | Requesting historical Daily data for ESZ14 starting at 2014-12-17 | 2015-01-12 13:58:33
Chart #1 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-12 13:58:33
Chart #2 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-12 13:58:33
Chart #3 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-12 13:58:33
Intraday data recording state for symbol TICK-NYSE is set to download pending. | 2015-01-12 13:58:33
HD Request # 3 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2015-01-12 13:58:33
HD Request # 3 | Download start Date-Time: 2015-01-12 13:58:14.0 | 2015-01-12 13:58:33
HD Request # 3 | Using server: ds4.sierracharts.com port 10149 | 2015-01-12 13:58:33
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-12 13:58:33
Intraday data recording state for symbol NISS-SP is set to download pending. | 2015-01-12 13:58:33
Intraday data recording state for symbol ESZ4-CME is set to download pending. | 2015-01-12 13:58:33
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-12 13:58:33
Intraday data recording state for symbol NISS-NYSE is set to download pending. | 2015-01-12 13:58:33
Intraday data recording state for symbol NISS-NQ is set to download pending. | 2015-01-12 13:58:33
Intraday data recording state for symbol NISS-TF is set to download pending. | 2015-01-12 13:58:33
HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-01-12 13:58:33
HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-01-12 13:58:33
HD Request # 2 | Receiving historical Daily data for ESZ14 starting at 2014-12-17 | 2015-01-12 13:58:33
Writing historical Daily data for ESZ14 to the file ESZ14.dly | 2015-01-12 13:58:33
HD Request # 2 | Received 3 records from 2014-12-17 00:00:00 to 2014-12-19 00:00:00 (3.0 days) and wrote 2 records for ESZ14 | 2015-01-12 13:58:33
HD Request # 2 | Daily download COMPLETE for ESZ14. Completion time: 0s. Unique request ID: 1 | 2015-01-12 13:58:33
Removed historical data download ID 1 | 2015-01-12 13:58:33
ESZ4-CME [CB] 120 Min #11: Download is complete for all contract months in chart. Proceeding with data load. | 2015-01-12 13:58:33
ESZ4-CME [CB] 120 Min #11: Performing continuous futures contract back adjustment calculations. | 2015-01-12 13:58:33
ESZ4-CME [CB] 120 Min #11: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2015-01-12 13:58:33
ESZ4-CME [CB] 120 Min #11: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2015-01-12 13:58:33
ESZ4-CME [CB] 120 Min #11: ESH4-CME price difference to ESM4-CME is -7.25. | 2015-01-12 13:58:33
ESZ4-CME [CB] 120 Min #11: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-12 13:58:33
ESZ4-CME [CB] 120 Min #11: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-12 13:58:33
ESZ4-CME [CB] 120 Min #11: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-12 13:58:33
ESZ4-CME [CB] 120 Min #11: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-12 13:58:33
ESZ4-CME [CB] 120 Min #11: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-12 13:58:33
ESZ4-CME [CB] 120 Min #11: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-12 13:58:33
ESZ4-CME [CB] 120 Min #11: Back adjust amount for symbol ESH4-CME is -22. | 2015-01-12 13:58:33
ESZ4-CME [CB] 120 Min #11: Back adjust amount for symbol ESM4-CME is -14.75. | 2015-01-12 13:58:33
ESZ4-CME [CB] 120 Min #11: Back adjust amount for symbol ESU4-CME is -7.75. | 2015-01-12 13:58:33
Rithmic Trading | Port for executable: 60548 | 2015-01-12 13:58:35
Listening socket (1968), port 60548 | Closed. | 2015-01-12 13:58:35
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-01-12 13:58:35
Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-12 13:58:36 *
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60548 | 2015-01-12 13:58:37
Socket (3) | Connected. | 2015-01-12 13:58:37
Rithmic Trading | Connected to server. | 2015-01-12 13:58:37
Rithmic Trading | Sending logon request message. | 2015-01-12 13:58:37
Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-12 13:58:37
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-01-12 13:58:37
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-01-12 13:58:37
Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-01-12 13:58:39
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2015-01-12 13:58:39
Rithmic Trading | Server Alert: Trading System Connection Opened | 2015-01-12 13:58:40
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2015-01-12 13:58:40
Rithmic Trading | subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2015-01-12 13:58:41
Rithmic Trading | Server Alert: PnL Connection Opened | 2015-01-12 13:58:41
Rithmic Trading | Server Alert: PnL Connection Login Complete. Result text: "ok" | 2015-01-12 13:58:41
Rithmic Trading | Server Alert: Intraday History Connection Opened | 2015-01-12 13:58:42
Rithmic Trading | Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2015-01-12 13:58:43
Rithmic Trading | Server Name: SC DTC Bridge. | 2015-01-12 13:58:43
Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-12 13:58:43
Rithmic Trading | Successfully connected. IB='OptimusFutures'. | 2015-01-12 13:58:43
Rithmic Trading | Trading is supported. | 2015-01-12 13:58:43
Rithmic Trading | Order cancel and replace is supported. | 2015-01-12 13:58:43
Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-12 13:58:43 *
Rithmic Trading | OCO Orders supported. | 2015-01-12 13:58:43
Rithmic Trading | Starting real-time market data updates for: ESZ4-CME. ID: 1 | 2015-01-12 13:58:43
Intraday data recording state for symbol ESZ4-CME is set to download pending. | 2015-01-12 13:58:43
Rithmic Trading | Received unknown message type from local socket. Disconnecting | 2015-01-12 13:58:43
Rithmic Trading | Starting real-time market data updates for: ESH5-CME. ID: 2 | 2015-01-12 13:58:43
Intraday data recording state for symbol ESH5-CME is set to download pending. | 2015-01-12 13:58:43
Rithmic Trading | Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available. | 2015-01-12 13:58:43
Symbol Error - ESZ4-CME is unknown, unavailable, or improperly formatted. | 2015-01-12 13:58:43
SC Market Stats | Starting real-time market data updates for: NISS-NYSE. ID: 3 | 2015-01-12 13:58:43
SC Market Stats | Connecting to the server ds5.sierracharts.com. Port 443 | 2015-01-12 13:58:43
Intraday data recording state for symbol NISS-NYSE is set to download pending. | 2015-01-12 13:58:43
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-12 13:58:43
SC Market Stats | Starting real-time market data updates for: TICK-NYSE. ID: 4 | 2015-01-12 13:58:43
Historical data request is discarded because it is not for earlier data. | 2015-01-12 13:58:43
Intraday data recording state for symbol TICK-NYSE has been reset to downloading. | 2015-01-12 13:58:43
SC Market Stats | Starting real-time market data updates for: NISS-NQ. ID: 5 | 2015-01-12 13:58:43
Intraday data recording state for symbol NISS-NQ is set to download pending. | 2015-01-12 13:58:43
SC Market Stats | Starting real-time market data updates for: NISS-SP. ID: 6 | 2015-01-12 13:58:43
Intraday data recording state for symbol NISS-SP is set to download pending. | 2015-01-12 13:58:43
SC Market Stats | Starting real-time market data updates for: NISS-TF. ID: 7 | 2015-01-12 13:58:43
Intraday data recording state for symbol NISS-TF is set to download pending. | 2015-01-12 13:58:43
Socket (4) | Connected. | 2015-01-12 13:58:43
SC Market Stats | Connected to server. | 2015-01-12 13:58:43
SC Market Stats | Sending logon request message. | 2015-01-12 13:58:43
Rithmic Trading | Starting real-time market data updates for: TF FMH0015!-NYBOT. ID: 8 | 2015-01-12 13:58:43
Intraday data recording state for symbol TF FMH0015!-NYBOT is set to download pending. | 2015-01-12 13:58:43
Rithmic Trading | Starting real-time market data updates for: NQH5-CME. ID: 9 | 2015-01-12 13:58:43
Intraday data recording state for symbol NQH5-CME is set to download pending. | 2015-01-12 13:58:43
SC Market Stats | Server Name: SC Realtime Server. | 2015-01-12 13:58:44
SC Market Stats | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-12 13:58:44
SC Market Stats | Successfully connected. | 2015-01-12 13:58:44
SC Market Stats | Restarting real-time data updates for symbol: NISS-NQ | 2015-01-12 13:58:44
SC Market Stats | Restarting real-time data updates for symbol: NISS-NYSE | 2015-01-12 13:58:44
SC Market Stats | Restarting real-time data updates for symbol: NISS-SP | 2015-01-12 13:58:44
SC Market Stats | Restarting real-time data updates for symbol: NISS-TF | 2015-01-12 13:58:44
SC Market Stats | Restarting real-time data updates for symbol: TICK-NYSE | 2015-01-12 13:58:44
Rithmic Trading | Requesting Trade Positions data. | 2015-01-12 13:58:48
Requesting market depth updates for: ESH5-CME if supported. | 2015-01-12 13:58:48
Socket (2) | Shutdown and closed. | 2015-01-12 13:58:53
HD Request # 3 | Error downloading historical Intraday data for TICK-NYSE. The network socket has been closed. Retrying download. | 2015-01-12 13:58:53 *
HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2015-01-12 13:58:53
HD Request # 4 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2015-01-12 13:58:53
HD Request # 4 | Download start Date-Time: 2015-01-12 13:58:14.0 | 2015-01-12 13:58:53
HD Request # 4 | Using server: ds3.sierracharts.com port 10149 | 2015-01-12 13:58:53
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-12 13:58:53
Socket (5) | Connected. | 2015-01-12 13:58:53
HD Request # 4 | Sending historical data logon request message. | 2015-01-12 13:58:53
HD Request # 4 | Requesting Intraday data. Start Date-Time: 2015-01-12 13:58:14. Record interval: 1. Symbol: TICK-NYSE | 2015-01-12 13:58:54
HD Request # 4 | Decompressing data. | 2015-01-12 13:58:54
HD Request # 4 | Receiving Intraday data for TICK-NYSE starting at 2015-01-12 13:58:14 | 2015-01-12 13:58:54
HD Request # 4 | Timestamp of first Intraday data file record written: 2015-01-12 13:58:14 | 2015-01-12 13:58:54
Socket (5) | Shutdown and closed. | 2015-01-12 13:58:54
The network socket for historical data has been closed. | 2015-01-12 13:58:54
HD Request # 4 | Received 39 records from 2015-01-12 13:58:14 to 2015-01-12 13:58:52 (38.0 seconds) and wrote 39 records for TICK-NYSE | 2015-01-12 13:58:54
HD Request # 4 | Intraday download COMPLETE for TICK-NYSE. Completion time: 1s. Unique request ID: 2 | 2015-01-12 13:58:54
Removed historical data download ID 2 | 2015-01-12 13:58:54
Real-time Intraday chart data file updates started for TICK-NYSE | 2015-01-12 13:58:54
HD Request # 5 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2015-01-12 13:58:54
HD Request # 5 | Download start Date-Time: 2015-01-12 13:58:14.0 | 2015-01-12 13:58:54
HD Request # 5 | Using server: ds4.sierracharts.com port 10149 | 2015-01-12 13:58:54
Chart #10 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-12 13:58:54
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-12 13:58:54
Socket (6) | Connected. | 2015-01-12 13:58:54
HD Request # 5 | Sending historical data logon request message. | 2015-01-12 13:58:54
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-12 13:58:54
HD Request # 5 | Requesting Intraday data. Start Date-Time: 2015-01-12 13:58:14. Record interval: 1. Symbol: NISS-SP | 2015-01-12 13:58:58
HD Request # 5 | Decompressing data. | 2015-01-12 13:58:58
HD Request # 5 | Receiving Intraday data for NISS-SP starting at 2015-01-12 13:58:14 | 2015-01-12 13:59:02
HD Request # 5 | Timestamp of first Intraday data file record written: 2015-01-12 13:58:14 | 2015-01-12 13:59:02
Socket (6) | Shutdown and closed. | 2015-01-12 13:59:02
The network socket for historical data has been closed. | 2015-01-12 13:59:02
HD Request # 5 | Received 44 records from 2015-01-12 13:58:14 to 2015-01-12 13:58:57 (43.0 seconds) and wrote 44 records for NISS-SP | 2015-01-12 13:59:02
HD Request # 5 | Intraday download COMPLETE for NISS-SP. Completion time: 8s. Unique request ID: 3 | 2015-01-12 13:59:02
Removed historical data download ID 3 | 2015-01-12 13:59:02
Real-time Intraday chart data file updates started for NISS-SP | 2015-01-12 13:59:02
HD Request # 6 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: cme | 2015-01-12 13:59:02
HD Request # 6 | Download start Date-Time: 2014-12-19 09:29:59.0 | 2015-01-12 13:59:02
HD Request # 6 | Using server: scdf2.sierracharts.com port 10149 | 2015-01-12 13:59:02
Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-01-12 13:59:02
Socket (7) | Connected. | 2015-01-12 13:59:02
HD Request # 6 | Sending historical data logon request message. | 2015-01-12 13:59:02
HD Request # 6 | Requesting Intraday data. Start Date-Time: 2014-12-19 09:29:59. Record interval: 1. Symbol: ESZ4 | 2015-01-12 13:59:02
Chart #7 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-12 13:59:02
HD Request # 6 | Decompressing data. | 2015-01-12 13:59:03
HD Request # 6 | Receiving Intraday data for ESZ4-CME starting at 2014-12-19 09:29:59 | 2015-01-12 13:59:03
HD Request # 6 | Timestamp of first Intraday data file record written: 2014-12-19 09:29:59 | 2015-01-12 13:59:03
Socket (7) | Shutdown and closed. | 2015-01-12 13:59:03
The network socket for historical data has been closed. | 2015-01-12 13:59:03
HD Request # 6 | Received 1 record from 2014-12-19 09:29:59 to 2014-12-19 09:29:59 (0.0 seconds) and wrote 1 record for ESZ4-CME | 2015-01-12 13:59:03
HD Request # 6 | Intraday download COMPLETE for ESZ4-CME. Completion time: 1s. Unique request ID: 4 | 2015-01-12 13:59:03
Removed historical data download ID 4 | 2015-01-12 13:59:03
Real-time Intraday chart data file updates started for ESZ4-CME | 2015-01-12 13:59:03
HD Request # 7 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2015-01-12 13:59:03
HD Request # 7 | Download start Date-Time: 2015-01-12 13:58:14.0 | 2015-01-12 13:59:03
HD Request # 7 | Using server: ds5.sierracharts.com port 10149 | 2015-01-12 13:59:03
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-12 13:59:03
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-12 13:59:03
Socket (8) | Connected. | 2015-01-12 13:59:03
HD Request # 7 | Sending historical data logon request message. | 2015-01-12 13:59:03
HD Request # 7 | Requesting Intraday data. Start Date-Time: 2015-01-12 13:58:14. Record interval: 1. Symbol: NISS-NYSE | 2015-01-12 13:59:04
HD Request # 7 | Decompressing data. | 2015-01-12 13:59:04
HD Request # 7 | Receiving Intraday data for NISS-NYSE starting at 2015-01-12 13:58:14 | 2015-01-12 13:59:04
HD Request # 7 | Timestamp of first Intraday data file record written: 2015-01-12 13:58:14 | 2015-01-12 13:59:04
Socket (8) | Shutdown and closed. | 2015-01-12 13:59:04
The network socket for historical data has been closed. | 2015-01-12 13:59:04
HD Request # 7 | Received 50 records from 2015-01-12 13:58:14 to 2015-01-12 13:59:03 (49.0 seconds) and wrote 50 records for NISS-NYSE | 2015-01-12 13:59:04
HD Request # 7 | Intraday download COMPLETE for NISS-NYSE. Completion time: 0s. Unique request ID: 5 | 2015-01-12 13:59:04
Removed historical data download ID 5 | 2015-01-12 13:59:04
Real-time Intraday chart data file updates started for NISS-NYSE | 2015-01-12 13:59:04
HD Request # 8 | Downloading Intraday chart data for NISS-NQ to the file NISS-NQ.scid. Service: statscalc | 2015-01-12 13:59:04
HD Request # 8 | Download start Date-Time: 2015-01-12 13:01:09.0 | 2015-01-12 13:59:04
HD Request # 8 | Using server: ds3.sierracharts.com port 10149 | 2015-01-12 13:59:04
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-12 13:59:04
Chart #1 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-12 13:59:04
Socket (9) | Connected. | 2015-01-12 13:59:05
HD Request # 8 | Sending historical data logon request message. | 2015-01-12 13:59:05
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-12 13:59:05
HD Request # 8 | Requesting Intraday data. Start Date-Time: 2015-01-12 13:01:09. Record interval: 1. Symbol: NISS-NQ | 2015-01-12 13:59:05
HD Request # 8 | Decompressing data. | 2015-01-12 13:59:05
HD Request # 8 | Receiving Intraday data for NISS-NQ starting at 2015-01-12 13:01:09 | 2015-01-12 13:59:05
HD Request # 8 | Timestamp of first Intraday data file record written: 2015-01-12 13:01:09 | 2015-01-12 13:59:05
Socket (9) | Shutdown and closed. | 2015-01-12 13:59:06
The network socket for historical data has been closed. | 2015-01-12 13:59:06
HD Request # 8 | Received 3473 records from 2015-01-12 13:01:09 to 2015-01-12 13:59:03 (57.9 minutes) and wrote 3473 records for NISS-NQ | 2015-01-12 13:59:06
HD Request # 8 | Intraday download COMPLETE for NISS-NQ. Completion time: 2s. Unique request ID: 6 | 2015-01-12 13:59:06
Removed historical data download ID 6 | 2015-01-12 13:59:06
Real-time Intraday chart data file updates started for NISS-NQ | 2015-01-12 13:59:06
HD Request # 9 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2015-01-12 13:59:06
HD Request # 9 | Download start Date-Time: 2015-01-12 12:45:02.0 | 2015-01-12 13:59:06
HD Request # 9 | Using server: ds4.sierracharts.com port 10149 | 2015-01-12 13:59:06
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-12 13:59:06
Chart #2 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-12 13:59:06
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-12 13:59:06
Socket (10) | Connected. | 2015-01-12 13:59:09
HD Request # 9 | Sending historical data logon request message. | 2015-01-12 13:59:09
HD Request # 9 | Requesting Intraday data. Start Date-Time: 2015-01-12 12:45:02. Record interval: 1. Symbol: NISS-TF | 2015-01-12 13:59:30
HD Request # 9 | Decompressing data. | 2015-01-12 13:59:30
HD Request # 9 | Receiving Intraday data for NISS-TF starting at 2015-01-12 12:45:02 | 2015-01-12 13:59:30
HD Request # 9 | Timestamp of first Intraday data file record written: 2015-01-12 12:45:02 | 2015-01-12 13:59:30
SC Market Stats | There has been no activity on the network socket. Will reconnect. | 2015-01-12 14:00:03 *
Socket (4) | Shutdown and closed. | 2015-01-12 14:00:03
SC Market Stats | Disconnected from the server. | 2015-01-12 14:00:03
SC Market Stats | Data feed disconnected. Will reconnect. | 2015-01-12 14:00:03
SC Market Stats | Connecting to the server ds5.sierracharts.com. Port 443 | 2015-01-12 14:00:05
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-12 14:00:05
Socket (11) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2015-01-12 14:00:26
Socket (11) | Shutdown and closed. | 2015-01-12 14:00:26
SC Market Stats | Disconnected from the server. | 2015-01-12 14:00:26
SC Market Stats | Data feed disconnected. Will reconnect. | 2015-01-12 14:00:26
SC Market Stats | Connecting to the server ds3.sierracharts.com. Port 443 | 2015-01-12 14:00:28
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-12 14:00:28
Socket (12) | Connected. | 2015-01-12 14:00:28
SC Market Stats | Connected to server. | 2015-01-12 14:00:28
SC Market Stats | Sending logon request message. | 2015-01-12 14:00:28
SC Market Stats | Server Name: SC Realtime Server. | 2015-01-12 14:00:29
SC Market Stats | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-12 14:00:29
SC Market Stats | Successfully connected. | 2015-01-12 14:00:29
Intraday data recording state for symbol NISS-NQ is set to download pending. | 2015-01-12 14:00:29
SC Market Stats | Restarting real-time data updates for symbol: NISS-NQ | 2015-01-12 14:00:29
Intraday data recording state for symbol NISS-NYSE is set to download pending. | 2015-01-12 14:00:29
SC Market Stats | Restarting real-time data updates for symbol: NISS-NYSE | 2015-01-12 14:00:29
Intraday data recording state for symbol NISS-SP is set to download pending. | 2015-01-12 14:00:29
SC Market Stats | Restarting real-time data updates for symbol: NISS-SP | 2015-01-12 14:00:29
SC Market Stats | Restarting real-time data updates for symbol: NISS-TF | 2015-01-12 14:00:29
Intraday data recording state for symbol TICK-NYSE is set to download pending. | 2015-01-12 14:00:29
SC Market Stats | Restarting real-time data updates for symbol: TICK-NYSE | 2015-01-12 14:00:29
HD Request # 9 | Error downloading historical Intraday data for NISS-TF. The download timed out. | 2015-01-12 14:02:30 *
Socket (10) | Shutdown and closed. | 2015-01-12 14:02:30
HD Request # 9 | Received 237 records from 2015-01-12 12:45:02 to 2015-01-12 12:48:58 (3.9 minutes) and wrote 237 records for NISS-TF | 2015-01-12 14:02:30
Added 245 Time and Sales records to Intraday data file for NISS-TF after download. | 2015-01-12 14:02:30
HD Request # 9 | Intraday download COMPLETE for NISS-TF. Completion time: 3m 24s. Unique request ID: 7 | 2015-01-12 14:02:30
Removed historical data download ID 7 | 2015-01-12 14:02:30
Real-time Intraday chart data file updates started for NISS-TF | 2015-01-12 14:02:30
HD Request # 10 | Downloading Intraday chart data for ESH5-CME to the file ESH5-CME.scid. Service: rim | 2015-01-12 14:02:30
HD Request # 10 | Download start Date-Time: 2015-01-12 12:51:09.0 | 2015-01-12 14:02:30
HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2015-01-12 14:02:30
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-12 14:02:30
Chart #3 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-12 14:02:30
Socket (13) | Connected. | 2015-01-12 14:02:30
HD Request # 10 | Sending historical data logon request message. | 2015-01-12 14:02:30
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-12 14:02:30
HD Request # 10 | Requesting Intraday data. Start Date-Time: 2015-01-12 12:51:09. Record interval: 1. Symbol: ESH5-CME | 2015-01-12 14:02:31
HD Request # 10 | Decompressing data. | 2015-01-12 14:02:31
HD Request # 10 | Receiving Intraday data for ESH5-CME starting at 2015-01-12 12:51:09 | 2015-01-12 14:02:31
HD Request # 10 | Timestamp of first Intraday data file record written: 2015-01-12 12:51:09 | 2015-01-12 14:02:31
Socket (13) | Shutdown and closed. | 2015-01-12 14:03:52
The network socket for historical data has been closed. | 2015-01-12 14:03:52
HD Request # 10 | Received 2864 records from 2015-01-12 12:51:09 to 2015-01-12 14:02:29 (71.3 minutes) and wrote 2864 records for ESH5-CME | 2015-01-12 14:03:52
Added 745 Time and Sales records to Intraday data file for ESH5-CME after download. | 2015-01-12 14:03:52
HD Request # 10 | Intraday download COMPLETE for ESH5-CME. Completion time: 1m 22s. Unique request ID: 9 | 2015-01-12 14:03:52
Removed historical data download ID 9 | 2015-01-12 14:03:52
Real-time Intraday chart data file updates started for ESH5-CME | 2015-01-12 14:03:52
HD Request # 11 | Downloading Intraday chart data for TF FMH0015!-NYBOT to the file TF FMH0015!-NYBOT.scid. Service: rim | 2015-01-12 14:03:52
HD Request # 11 | Download start Date-Time: 2015-01-12 12:45:02.0 | 2015-01-12 14:03:52
HD Request # 11 | Using server: ds5.sierracharts.com port 10149 | 2015-01-12 14:03:52
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-12 14:03:52
Chart #4 has tagged chart #9 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-12 14:03:53
Chart #9 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-12 14:03:53
Socket (14) | Connected. | 2015-01-12 14:03:53
HD Request # 11 | Sending historical data logon request message. | 2015-01-12 14:03:53
Chart #15 has tagged chart #9 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-12 14:03:53
Chart #9 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-12 14:03:54
HD Request # 11 | Requesting Intraday data. Start Date-Time: 2015-01-12 12:45:02. Record interval: 1. Symbol: TF FMH0015!-NYBOT | 2015-01-12 14:03:54
HD Request # 11 | Decompressing data. | 2015-01-12 14:03:55
HD Request # 11 | Receiving Intraday data for TF FMH0015!-NYBOT starting at 2015-01-12 12:45:02 | 2015-01-12 14:03:55
HD Request # 11 | Timestamp of first Intraday data file record written: 2015-01-12 12:45:02 | 2015-01-12 14:03:55
Socket (14) | Shutdown and closed. | 2015-01-12 14:04:00
The network socket for historical data has been closed. | 2015-01-12 14:04:00
HD Request # 11 | Received 1721 records from 2015-01-12 12:45:02 to 2015-01-12 14:03:51 (78.8 minutes) and wrote 1721 records for TF FMH0015!-NYBOT | 2015-01-12 14:04:00
HD Request # 11 | Intraday download COMPLETE for TF FMH0015!-NYBOT. Completion time: 8s. Unique request ID: 15 | 2015-01-12 14:04:00
Removed historical data download ID 15 | 2015-01-12 14:04:00
Real-time Intraday chart data file updates started for TF FMH0015!-NYBOT | 2015-01-12 14:04:00
HD Request # 12 | Downloading Intraday chart data for NQH5-CME to the file NQH5-CME.scid. Service: rim | 2015-01-12 14:04:00
HD Request # 12 | Download start Date-Time: 2015-01-12 12:45:02.0 | 2015-01-12 14:04:00
HD Request # 12 | Using server: ds3.sierracharts.com port 10149 | 2015-01-12 14:04:00
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-12 14:04:00
Socket (15) | Connected. | 2015-01-12 14:04:00
HD Request # 12 | Sending historical data logon request message. | 2015-01-12 14:04:00
HD Request # 12 | Requesting Intraday data. Start Date-Time: 2015-01-12 12:45:02. Record interval: 1. Symbol: NQH5-CME | 2015-01-12 14:04:00
HD Request # 12 | Decompressing data. | 2015-01-12 14:04:00
HD Request # 12 | Receiving Intraday data for NQH5-CME starting at 2015-01-12 12:45:02 | 2015-01-12 14:04:01
HD Request # 12 | Timestamp of first Intraday data file record written: 2015-01-12 12:45:02 | 2015-01-12 14:04:01
Socket (15) | Shutdown and closed. | 2015-01-12 14:04:01
The network socket for historical data has been closed. | 2015-01-12 14:04:01
HD Request # 12 | Received 2879 records from 2015-01-12 12:45:02 to 2015-01-12 14:03:58 (78.9 minutes) and wrote 2879 records for NQH5-CME | 2015-01-12 14:04:01
HD Request # 12 | Intraday download COMPLETE for NQH5-CME. Completion time: 1s. Unique request ID: 16 | 2015-01-12 14:04:01
Removed historical data download ID 16 | 2015-01-12 14:04:01
Real-time Intraday chart data file updates started for NQH5-CME | 2015-01-12 14:04:01
HD Request # 13 | Downloading Intraday chart data for NISS-NQ to the file NISS-NQ.scid. Service: statscalc | 2015-01-12 14:04:01
HD Request # 13 | Download start Date-Time: 2015-01-12 13:59:03.0 | 2015-01-12 14:04:01
HD Request # 13 | Using server: ds4.sierracharts.com port 10149 | 2015-01-12 14:04:01
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-12 14:04:01
Socket (16) | Connected. | 2015-01-12 14:04:01
HD Request # 13 | Sending historical data logon request message. | 2015-01-12 14:04:01
HD Request # 13 | Requesting Intraday data. Start Date-Time: 2015-01-12 13:59:03. Record interval: 1. Symbol: NISS-NQ | 2015-01-12 14:04:09
HD Request # 13 | Decompressing data. | 2015-01-12 14:04:09
HD Request # 13 | Receiving Intraday data for NISS-NQ starting at 2015-01-12 13:59:03 | 2015-01-12 14:04:09
HD Request # 13 | Timestamp of first Intraday data file record written: 2015-01-12 13:59:03 | 2015-01-12 14:04:09
Socket (16) | Shutdown and closed. | 2015-01-12 14:04:09
The network socket for historical data has been closed. | 2015-01-12 14:04:09
HD Request # 13 | Received 306 records from 2015-01-12 13:59:03 to 2015-01-12 14:04:08 (5.1 minutes) and wrote 306 records for NISS-NQ | 2015-01-12 14:04:09
Added 1 Time and Sales records to Intraday data file for NISS-NQ after download. | 2015-01-12 14:04:09
HD Request # 13 | Intraday download COMPLETE for NISS-NQ. Completion time: 8s. Unique request ID: 17 | 2015-01-12 14:04:09
Removed historical data download ID 17 | 2015-01-12 14:04:09
Real-time Intraday chart data file updates started for NISS-NQ | 2015-01-12 14:04:09
HD Request # 14 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2015-01-12 14:04:09
HD Request # 14 | Download start Date-Time: 2015-01-12 13:59:03.0 | 2015-01-12 14:04:09
HD Request # 14 | Using server: ds5.sierracharts.com port 10149 | 2015-01-12 14:04:09
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-12 14:04:09
Socket (17) | Connected. | 2015-01-12 14:04:09
HD Request # 14 | Sending historical data logon request message. | 2015-01-12 14:04:09
Chart #2 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-12 14:04:09
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-12 14:04:10
HD Request # 14 | Requesting Intraday data. Start Date-Time: 2015-01-12 13:59:03. Record interval: 1. Symbol: NISS-NYSE | 2015-01-12 14:04:10
HD Request # 14 | Decompressing data. | 2015-01-12 14:04:12
HD Request # 14 | Receiving Intraday data for NISS-NYSE starting at 2015-01-12 13:59:03 | 2015-01-12 14:04:12
HD Request # 14 | Timestamp of first Intraday data file record written: 2015-01-12 13:59:03 | 2015-01-12 14:04:12
Socket (17) | Shutdown and closed. | 2015-01-12 14:04:17
The network socket for historical data has been closed. | 2015-01-12 14:04:17
HD Request # 14 | Received 308 records from 2015-01-12 13:59:03 to 2015-01-12 14:04:10 (5.1 minutes) and wrote 308 records for NISS-NYSE | 2015-01-12 14:04:17
Added 12 Time and Sales records to Intraday data file for NISS-NYSE after download. | 2015-01-12 14:04:17
HD Request # 14 | Intraday download COMPLETE for NISS-NYSE. Completion time: 8s. Unique request ID: 18 | 2015-01-12 14:04:17
Removed historical data download ID 18 | 2015-01-12 14:04:17
Real-time Intraday chart data file updates started for NISS-NYSE | 2015-01-12 14:04:17
HD Request # 15 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2015-01-12 14:04:17
HD Request # 15 | Download start Date-Time: 2015-01-12 13:58:57.0 | 2015-01-12 14:04:17
HD Request # 15 | Using server: ds3.sierracharts.com port 10149 | 2015-01-12 14:04:17
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-12 14:04:17
Socket (18) | Connected. | 2015-01-12 14:04:17
HD Request # 15 | Sending historical data logon request message. | 2015-01-12 14:04:17
HD Request # 15 | Requesting Intraday data. Start Date-Time: 2015-01-12 13:58:57. Record interval: 1. Symbol: NISS-SP | 2015-01-12 14:04:17
Chart #1 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-12 14:04:17
HD Request # 15 | Decompressing data. | 2015-01-12 14:04:18
HD Request # 15 | Receiving Intraday data for NISS-SP starting at 2015-01-12 13:58:57 | 2015-01-12 14:04:18
HD Request # 15 | Timestamp of first Intraday data file record written: 2015-01-12 13:58:57 | 2015-01-12 14:04:18
Socket (18) | Shutdown and closed. | 2015-01-12 14:04:18
The network socket for historical data has been closed. | 2015-01-12 14:04:18
HD Request # 15 | Received 320 records from 2015-01-12 13:58:57 to 2015-01-12 14:04:16 (5.3 minutes) and wrote 320 records for NISS-SP | 2015-01-12 14:04:18
Added 1 Time and Sales records to Intraday data file for NISS-SP after download. | 2015-01-12 14:04:18
HD Request # 15 | Intraday download COMPLETE for NISS-SP. Completion time: 0s. Unique request ID: 19 | 2015-01-12 14:04:18
Removed historical data download ID 19 | 2015-01-12 14:04:18
Real-time Intraday chart data file updates started for NISS-SP | 2015-01-12 14:04:18
HD Request # 16 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2015-01-12 14:04:18
HD Request # 16 | Download start Date-Time: 2015-01-12 13:58:52.0 | 2015-01-12 14:04:18
HD Request # 16 | Using server: ds4.sierracharts.com port 10149 | 2015-01-12 14:04:18
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-12 14:04:18
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-12 14:04:18
Chart #7 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-12 14:04:18
Socket (19) | Connected. | 2015-01-12 14:04:27
HD Request # 16 | Sending historical data logon request message. | 2015-01-12 14:04:27
HD Request # 16 | Requesting Intraday data. Start Date-Time: 2015-01-12 13:58:52. Record interval: 1. Symbol: TICK-NYSE | 2015-01-12 14:04:27
HD Request # 16 | Decompressing data. | 2015-01-12 14:04:27
HD Request # 16 | Receiving Intraday data for TICK-NYSE starting at 2015-01-12 13:58:52 | 2015-01-12 14:04:29
HD Request # 16 | Timestamp of first Intraday data file record written: 2015-01-12 13:58:52 | 2015-01-12 14:04:29
Socket (19) | Shutdown and closed. | 2015-01-12 14:04:33
The network socket for historical data has been closed. | 2015-01-12 14:04:33
HD Request # 16 | Received 335 records from 2015-01-12 13:58:52 to 2015-01-12 14:04:26 (5.6 minutes) and wrote 335 records for TICK-NYSE | 2015-01-12 14:04:33
Added 24 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2015-01-12 14:04:33
HD Request # 16 | Intraday download COMPLETE for TICK-NYSE. Completion time: 15s. Unique request ID: 20 | 2015-01-12 14:04:33
Removed historical data download ID 20 | 2015-01-12 14:04:33
Real-time Intraday chart data file updates started for TICK-NYSE | 2015-01-12 14:04:33
Chart #10 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-12 14:04:33
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-12 14:04:33
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:04:38
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:04:38
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:04:38
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:04:38
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:04:38
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:04:38
ESH5-CME [CB] 5 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:04:38
ESZ4-CME | 2015-01-12 14:04:38
ESH5-CME | 2015-01-12 14:04:38
ESH5-CME [CB] 5 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:04:38
ESH5-CME [CB] 5 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:04:38
ESH5-CME [CB] 5 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:04:38
ESH5-CME [CB] 5 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:04:38
ESH5-CME [CB] 5 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:04:38
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:11:45
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:11:45
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:11:45
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:11:45
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:11:45
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:11:45
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:11:45
ESZ4-CME | 2015-01-12 14:11:45
ESH5-CME | 2015-01-12 14:11:45
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:11:45
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:11:45
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:11:45
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:11:45
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:11:45
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:12:56
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:12:56
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:12:56
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:12:56
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:12:56
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:12:56
ESH5-CME [CB] 5 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:12:56
ESZ4-CME | 2015-01-12 14:12:56
ESH5-CME | 2015-01-12 14:12:56
ESH5-CME [CB] 5 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:12:56
ESH5-CME [CB] 5 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:12:56
ESH5-CME [CB] 5 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:12:56
ESH5-CME [CB] 5 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:12:56
ESH5-CME [CB] 5 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:12:56
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:14:14
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:14:14
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:14:14
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:14:14
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:14:14
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:14:14
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:14:14
ESZ4-CME | 2015-01-12 14:14:14
ESH5-CME | 2015-01-12 14:14:14
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:14:14
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:14:14
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:14:14
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:14:14
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:14:14
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:18:02
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:18:02
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:18:02
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:18:02
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:18:02
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:18:02
ESH5-CME [CB] 5 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:18:02
ESZ4-CME | 2015-01-12 14:18:02
ESH5-CME | 2015-01-12 14:18:02
ESH5-CME [CB] 5 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:18:02
ESH5-CME [CB] 5 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:18:02
ESH5-CME [CB] 5 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:18:02
ESH5-CME [CB] 5 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:18:02
ESH5-CME [CB] 5 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:18:02
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:18:21
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:18:21
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:18:21
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:18:21
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:18:21
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:18:21
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:18:21
ESZ4-CME | 2015-01-12 14:18:21
ESH5-CME | 2015-01-12 14:18:21
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:18:21
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:18:21
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:18:21
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:18:21
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:18:21
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:19:40
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:19:40
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:19:40
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:19:40
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:19:40
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:19:40
ESH5-CME [CB] 5 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:19:40
ESZ4-CME | 2015-01-12 14:19:40
ESH5-CME | 2015-01-12 14:19:40
ESH5-CME [CB] 5 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:19:40
ESH5-CME [CB] 5 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:19:40
ESH5-CME [CB] 5 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:19:40
ESH5-CME [CB] 5 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:19:40
ESH5-CME [CB] 5 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:19:40
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:20:03
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:20:03
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:20:03
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:20:03
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:20:03
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:20:03
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:20:03
ESZ4-CME | 2015-01-12 14:20:03
ESH5-CME | 2015-01-12 14:20:03
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:20:03
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:20:03
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:20:03
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:20:03
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:20:03
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:24:15
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:24:15
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:24:15
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:24:15
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:24:15
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:24:15
ESH5-CME [CB] 5 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:24:15
ESZ4-CME | 2015-01-12 14:24:15
ESH5-CME | 2015-01-12 14:24:15
ESH5-CME [CB] 5 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:24:15
ESH5-CME [CB] 5 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:24:15
ESH5-CME [CB] 5 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:24:15
ESH5-CME [CB] 5 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:24:15
ESH5-CME [CB] 5 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:24:15
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:24:25
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:24:25
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:24:25
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:24:25
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:24:25
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:24:25
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:24:25
ESZ4-CME | 2015-01-12 14:24:25
ESH5-CME | 2015-01-12 14:24:25
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:24:25
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:24:25
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:24:25
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:24:25
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:24:25
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:28:18
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:28:18
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:28:18
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:28:18
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:28:18
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:28:18
ESH5-CME [CB] 5 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:28:18
ESZ4-CME | 2015-01-12 14:28:18
ESH5-CME | 2015-01-12 14:28:18
ESH5-CME [CB] 5 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:28:18
ESH5-CME [CB] 5 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:28:18
ESH5-CME [CB] 5 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:28:18
ESH5-CME [CB] 5 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:28:18
ESH5-CME [CB] 5 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:28:18
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:28:26
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:28:26
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:28:26
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:28:26
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:28:26
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:28:26
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:28:26
ESZ4-CME | 2015-01-12 14:28:26
ESH5-CME | 2015-01-12 14:28:26
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:28:26
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:28:26
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:28:26
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:28:26
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:28:26
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:32:17
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:32:17
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:32:17
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:32:17
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:32:17
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:32:17
ESH5-CME [CB] 5 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:32:17
ESZ4-CME | 2015-01-12 14:32:17
ESH5-CME | 2015-01-12 14:32:17
ESH5-CME [CB] 5 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:32:17
ESH5-CME [CB] 5 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:32:17
ESH5-CME [CB] 5 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:32:17
ESH5-CME [CB] 5 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:32:17
ESH5-CME [CB] 5 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:32:17
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:32:35
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:32:35
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:32:35
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:32:35
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:32:35
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:32:35
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:32:35
ESZ4-CME | 2015-01-12 14:32:35
ESH5-CME | 2015-01-12 14:32:35
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:32:35
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:32:35
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:32:35
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:32:35
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:32:35
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:34:26
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:34:26
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:34:26
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:34:26
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:34:26
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:34:26
ESH5-CME [CB] 5 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:34:26
ESZ4-CME | 2015-01-12 14:34:26
ESH5-CME | 2015-01-12 14:34:26
ESH5-CME [CB] 5 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:34:26
ESH5-CME [CB] 5 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:34:26
ESH5-CME [CB] 5 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:34:26
ESH5-CME [CB] 5 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:34:26
ESH5-CME [CB] 5 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:34:26
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:34:56
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:34:56
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:34:56
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:34:56
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:34:56
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:34:56
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:34:56
ESZ4-CME | 2015-01-12 14:34:56
ESH5-CME | 2015-01-12 14:34:56
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:34:56
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:34:56
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:34:56
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:34:56
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:34:56
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:37:09
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:37:09
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:37:09
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:37:09
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:37:09
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:37:09
ESH5-CME [CB] 5 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:37:09
ESZ4-CME | 2015-01-12 14:37:09
ESH5-CME | 2015-01-12 14:37:09
ESH5-CME [CB] 5 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:37:09
ESH5-CME [CB] 5 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:37:09
ESH5-CME [CB] 5 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:37:09
ESH5-CME [CB] 5 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:37:09
ESH5-CME [CB] 5 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:37:09
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:38:12
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:38:12
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:38:12
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:38:12
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:38:12
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:38:12
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:38:12
ESZ4-CME | 2015-01-12 14:38:12
ESH5-CME | 2015-01-12 14:38:12
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:38:12
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:38:12
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:38:12
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:38:12
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:38:12
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:38:48
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:38:48
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:38:48
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:38:48
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:38:48
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:38:48
ESH5-CME [CB] 5 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:38:48
ESZ4-CME | 2015-01-12 14:38:48
ESH5-CME | 2015-01-12 14:38:48
ESH5-CME [CB] 5 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:38:48
ESH5-CME [CB] 5 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:38:48
ESH5-CME [CB] 5 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:38:48
ESH5-CME [CB] 5 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:38:48
ESH5-CME [CB] 5 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:38:48
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:39:02
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:39:02
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:39:02
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:39:02
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:39:02
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:39:02
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:39:02
ESZ4-CME | 2015-01-12 14:39:02
ESH5-CME | 2015-01-12 14:39:02
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:39:02
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:39:02
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:39:02
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:39:02
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:39:02
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:40:28
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:40:28
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:40:28
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:40:28
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:40:28
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:40:28
ESH5-CME [CB] 5 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:40:28
ESZ4-CME | 2015-01-12 14:40:28
ESH5-CME | 2015-01-12 14:40:28
ESH5-CME [CB] 5 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:40:28
ESH5-CME [CB] 5 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:40:28
ESH5-CME [CB] 5 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:40:28
ESH5-CME [CB] 5 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:40:28
ESH5-CME [CB] 5 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:40:28
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:41:52
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:41:52
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:41:52
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:41:52
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:41:52
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:41:52
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:41:52
ESZ4-CME | 2015-01-12 14:41:52
ESH5-CME | 2015-01-12 14:41:52
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:41:52
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:41:52
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:41:52
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:41:52
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:41:52
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:42:12
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:42:12
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:42:12
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:42:12
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:42:12
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:42:12
ESH5-CME [CB] 5 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:42:12
ESZ4-CME | 2015-01-12 14:42:12
ESH5-CME | 2015-01-12 14:42:12
ESH5-CME [CB] 5 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:42:12
ESH5-CME [CB] 5 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:42:12
ESH5-CME [CB] 5 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:42:12
ESH5-CME [CB] 5 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:42:12
ESH5-CME [CB] 5 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:42:12
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:42:46
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:42:46
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:42:46
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:42:46
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:42:46
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:42:46
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:42:46
ESZ4-CME | 2015-01-12 14:42:46
ESH5-CME | 2015-01-12 14:42:46
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:42:46
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:42:46
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:42:46
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:42:46
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:42:46
Date rule based rollover from TF FMZ0014!-NYBOT to next contract occurs at 2014-12-11. | 2015-01-12 14:46:56
Date rule based rollover from TF FMH0015!-NYBOT to next contract occurs at 2015-03-12. | 2015-01-12 14:46:56
Checking Intraday data file for symbol TF FMZ0014!-NYBOT for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:46:56
Checking Daily data file for symbol RJZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:46:56
Checking Intraday data file for symbol TF FMH0015!-NYBOT for the date range from 2014-12-11 to 0. | 2015-01-12 14:46:56
Checking Daily data file for symbol RJH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:46:56
TF FMH0015!-NYBOT [CB] 10 Min #12 | Symbols used for continuous contract chart: | 2015-01-12 14:46:56
TF FMZ0014!-NYBOT | 2015-01-12 14:46:56
TF FMH0015!-NYBOT | 2015-01-12 14:46:56
TF FMH0015!-NYBOT [CB] 10 Min #12: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:46:56
TF FMH0015!-NYBOT [CB] 10 Min #12: TF FMZ0014!-NYBOT Open price on 2014-12-11 is 1162.2. | 2015-01-12 14:46:56
TF FMH0015!-NYBOT [CB] 10 Min #12: TF FMH0015!-NYBOT Open price on 2014-12-11 is 1157.5. | 2015-01-12 14:46:56
TF FMH0015!-NYBOT [CB] 10 Min #12: TF FMZ0014!-NYBOT price difference to TF FMH0015!-NYBOT is -4.6999998. | 2015-01-12 14:46:56
TF FMH0015!-NYBOT [CB] 10 Min #12: Back adjust amount for symbol TF FMZ0014!-NYBOT is -4.6999998. | 2015-01-12 14:46:56
Date rule based rollover from TF FMZ0014!-NYBOT to next contract occurs at 2014-12-11. | 2015-01-12 14:47:10
Date rule based rollover from TF FMH0015!-NYBOT to next contract occurs at 2015-03-12. | 2015-01-12 14:47:10
Checking Intraday data file for symbol TF FMZ0014!-NYBOT for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:47:10
Checking Daily data file for symbol RJZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:47:10
Checking Intraday data file for symbol TF FMH0015!-NYBOT for the date range from 2014-12-11 to 0. | 2015-01-12 14:47:10
Checking Daily data file for symbol RJH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:47:10
TF FMH0015!-NYBOT [CB] 5 Min #12 | Symbols used for continuous contract chart: | 2015-01-12 14:47:10
TF FMZ0014!-NYBOT | 2015-01-12 14:47:10
TF FMH0015!-NYBOT | 2015-01-12 14:47:10
TF FMH0015!-NYBOT [CB] 5 Min #12: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:47:10
TF FMH0015!-NYBOT [CB] 5 Min #12: TF FMZ0014!-NYBOT Open price on 2014-12-11 is 1162.2. | 2015-01-12 14:47:10
TF FMH0015!-NYBOT [CB] 5 Min #12: TF FMH0015!-NYBOT Open price on 2014-12-11 is 1157.5. | 2015-01-12 14:47:10
TF FMH0015!-NYBOT [CB] 5 Min #12: TF FMZ0014!-NYBOT price difference to TF FMH0015!-NYBOT is -4.6999998. | 2015-01-12 14:47:10
TF FMH0015!-NYBOT [CB] 5 Min #12: Back adjust amount for symbol TF FMZ0014!-NYBOT is -4.6999998. | 2015-01-12 14:47:10
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:47:17
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:47:17
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:47:17
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:47:17
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:47:17
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:47:17
ESH5-CME [CB] 5 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:47:17
ESZ4-CME | 2015-01-12 14:47:17
ESH5-CME | 2015-01-12 14:47:17
ESH5-CME [CB] 5 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:47:17
ESH5-CME [CB] 5 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:47:17
ESH5-CME [CB] 5 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:47:17
ESH5-CME [CB] 5 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:47:17
ESH5-CME [CB] 5 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:47:17
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:47:39
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:47:39
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:47:39
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:47:39
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:47:39
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:47:39
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:47:39
ESZ4-CME | 2015-01-12 14:47:39
ESH5-CME | 2015-01-12 14:47:39
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:47:39
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:47:39
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:47:39
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:47:39
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:47:39
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:48:45
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:48:45
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:48:45
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:48:45
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:48:45
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:48:45
ESH5-CME [CB] 5 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:48:45
ESZ4-CME | 2015-01-12 14:48:45
ESH5-CME | 2015-01-12 14:48:45
ESH5-CME [CB] 5 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:48:45
ESH5-CME [CB] 5 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:48:45
ESH5-CME [CB] 5 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:48:45
ESH5-CME [CB] 5 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:48:45
ESH5-CME [CB] 5 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:48:45
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-12 14:49:20
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-12 14:49:20
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:49:20
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-12 14:49:20
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-12 14:49:20
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-12. | 2015-01-12 14:49:20
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-12 14:49:20
ESZ4-CME | 2015-01-12 14:49:20
ESH5-CME | 2015-01-12 14:49:20
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-12 14:49:20
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-12 14:49:20
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-12 14:49:20
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-12 14:49:20
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-12 14:49:20
[2015-01-12 22:24:52]
This is normal as part of the Continuous Futures Contract price adjustments:
Why does it keep performing back adjusted calculations?
[2020-04-24 12:07:10]
opci - Posts: 90
Hi. can i delete the whole logs.just leave the folder in the sc. folder i have too much gb occupied over 10 gb,,
and does it have to be SierraChartInstance_2 in the main folder? or can it also be deleted? thank you
[2020-04-24 18:51:38]
If you do not need any of the logs, then they can be safely deleted.
The folder SierraChartInstance_2 is present due to having selected File >> New Instance. If you do not use a second instance at all, then this too can be removed. But if you do use a second instance on occasion, then you will want to leave that folder.
Also, refer to the information here for cleaning up unused symbols:
Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency
Date Time Of Last Edit: 2020-04-24 18:52:18
