Date/Time: Sun, 22 Nov 2026 08:03:20 +0000
Request for the new spreadsheets
View Count: 1254
[2015-01-04 18:47:17]
George - Posts: 60
If it is not too difficult, add the "Fix Column" and "Fix Row" option, like the old spreadsheets.
[2015-01-04 21:39:44]
Sawtooth - Posts: 4362
+1
[2015-01-07 18:27:44]
We will look into this.
[2015-01-08 09:26:29]
inverter - Posts: 42
Regards,, I want to put a cross with two movin average and if I can use these examples, I want to put my adapted MA,,, if I should change the numbers? I'm trying but it does not work,, what am I doing wrong?
Format: CROSSOVER(range1, range2)
Example: =CROSSOVER(AA3:AA4,AB3:AB4)
Example: =CROSSOVER( {1, 2}, { 2, 1})
Example: =CROSSOVER(AA3:AA4, { 1, 1})
Example: =CROSSOVER(E3:E5, AA3:AA5)
imagenumber study.png / V - Attached On 2015-01-08 09:25:50 UTC - Size: 67.09 KB - 461 views
