Date/Time: Wed, 25 Nov 2026 10:22:18 +0000
[User Discussion] - Trade Activity Log - Currency
View Count: 1151
| [2014-12-17 08:43:57] |
| User78442 - Posts: 260 |
Hi, I want to export the "Trades" log to a spreadsheet but when I set the P/L to Currency on some the FX pairs, any currency cell has USD added to the cell e.g. $8 is 8.00USD - How do I get rid of the USD label? Also is there an area where I can fix the levels at which the FX calculations are made? |
| [2014-12-17 10:15:21] |
You can disable the conversion to the common currency through Global Settings >> General Trade Settings. We do not understand the other question and it does not sound like something we can help with anyway. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-12-17 10:49:30] |
I don't want to disable the conversion, I just want to make sure the print is just the value NOT including the USD label. Why does this appear in FX trades but not the futures?
