Date/Time: Wed, 25 Nov 2026 11:20:20 +0000
Getting this message when compiling
View Count: 1188
| [2014-12-17 03:26:01] |
| CMG - Posts: 179 |
http://www.sierrachart.com/image.php?l=1418786654215.png Is there a way not to get this everytime I compile a .ccp Thanks in advance |
| [2014-12-17 04:21:10] |
Yes. Set sc.FreeDLL = 1.
| [2014-12-17 17:32:23] |
| CMG - Posts: 179 |
Since I have many studies in the same .ccp should I change it in each one of them or just in the study I am working on? Tks again... |
| [2014-12-17 20:58:50] |
All of them. And the file extension is .cpp Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
