Date/Time: Sat, 07 Nov 2026 13:57:40 +0000
Single point on new high or low.
View Count: 1422
| [2014-12-14 20:41:27] |
| Rino - Posts: 124 |
Hi, I have 'New Daily High/New Daily Low' study on my TICK chart. How do I get it to show just a point on only the new high and new low? (1 point) Thanks http://www.sierrachart.com/image.php?l=141858960176.png |
| [2014-12-17 03:02:04] |
| Rino - Posts: 124 |
Can I get it to show a point (marker) on just the high and low TICK of the day. I can get a line, but just want one point on the high and low for the day. Thanks |
| [2014-12-17 04:19:01] |
Have a look at the Daily OHLC Single Point study to see if it does what you need: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s239 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
