Date/Time: Tue, 27 Oct 2026 04:10:48 +0000
CTS fix disconnections
View Count: 1253
| [2014-12-12 19:09:12] |
| User90069 - Posts: 4 |
Hello Is anybody else having reliability issues with cts? All week I've been experiencing disconnections(cl) through SC and cts' platform. CTS FIX socket (2436) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2014-12-12 14:04:45 CTS FIX socket (2436) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-12 14:04:45 CTS FIX socket (2436) | SSL has been shut down. | 2014-12-12 14:04:45 CTS FIX socket (2436) | SSL object has been freed. SSL state is now disconnected. | 2014-12-12 14:04:45 CTS FIX socket (2436) | Shutdown and closed. | 2014-12-12 14:04:45 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-12-12 14:04:45 Connection to the external service has been lost. | 2014-12-12 14:04:45 Date Time Of Last Edit: 2014-12-12 19:15:00
| [2014-12-12 19:12:50] |
FWIW this is a dedicated machine with virus/firewall etc disabled. Complete message logs have been forwarded to support. CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-12-12 13:50:22 CTS FIX - Firm: DORMAN | 2014-12-12 13:50:22 CTS FIX: Unable to connect. The last connection is still in the process of logging out. | 2014-12-12 13:50:22 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-12 13:50:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-12 13:50:22 CTS FIX: Disconnected. | 2014-12-12 13:50:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-12 13:50:22 CTS FIX: Waiting for Logout response timed out. Closing the socket now. | 2014-12-12 13:50:23 * CTS FIX socket (2436) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-12 13:50:23 CTS FIX socket (2436) | SSL has been shut down. | 2014-12-12 13:50:23 CTS FIX socket (2436) | SSL object has been freed. SSL state is now disconnected. | 2014-12-12 13:50:23 CTS FIX socket (2436) | Shutdown and closed. | 2014-12-12 13:50:23 CTS FIX: Socket closed without completing the logout sequence. | 2014-12-12 13:50:23 CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-12-12 13:50:25 CTS FIX - Firm: DORMAN | 2014-12-12 13:50:25 CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-12-12 13:50:26 CTS FIX socket (2436) | Connected. | 2014-12-12 13:50:26 CTS FIX socket (2436) | Starting SSL connection. | 2014-12-12 13:50:26 CTS FIX socket (2436) | SSL connection established. | 2014-12-12 13:50:26 CTS FIX: Sending the Logon message. | 2014-12-12 13:50:26 CTS FIX: Connected to data and trade server. FIX version: 4.3.17.0 | 2014-12-12 13:50:26 |
| [2014-12-12 20:47:15] |
How many symbols are you tracking within Sierra Chart?
