Date/Time: Tue, 27 Oct 2026 04:10:53 +0000
Daily chart displaying outsized last bar
View Count: 1145
| [2014-12-12 18:48:29] |
| Demi1201 - Posts: 68 |
Hello, This is a pictture of my daily chart for emini soybeans. This only happens with this specific chart, and only for the daily timeframe. Subdaily timeframes are ok. http://www.sierrachart.com/image.php?l=1418409993479.png Please advise, GB |
| [2014-12-13 03:23:12] |
This has now been corrected. However, the Interactive Brokers symbol was incorrect. This is the new symbol: YK-######-ECBOT-USD-1000 Follow the instructions here to update symbol settings: Global Symbol Settings: Update Global Symbol Settings So you will need to change the symbol of the chart by following these instructions: Changing the Symbol of a Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
