Date/Time: Tue, 27 Oct 2026 04:11:14 +0000
display date and/or time on horizontal rays
View Count: 1229
| [2014-12-12 10:47:14] |
| User50124 - Posts: 2 |
Hello, I see on horizontal ray properties is lot of inactive labels. I need date and time dispayed for my drawings. Is it possible to activate them? See attached file. |
| Attachment Deleted. |
| [2014-12-12 18:09:51] |
No, this is not supported with that drawing.
