Date/Time: Wed, 16 Sep 2026 23:06:03 +0000
can you check the symbol J7Z4?
View Count: 1187
| [2014-12-11 17:21:31] |
| infpz - Posts: 826 |
It is available through Transact (like the E7Z4 symbol) but I am getting a “download failed” message when I try to open a chart for it.
| [2014-12-11 18:17:23] |
This does not make sense. Go to the chart again and select Edit >> Delete All Data and Download. If there still is a problem, post the last 40 lines of the Message Log here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-12-11 18:23:44] |
Same thing. FYI, this is not a commonly used symbol and it is not in the list under FS > Futures. Intraday data recording state for symbol J7Z4 is set to download pending. | 2014-12-11 12:23:06 Reloading all charts with filename: J7Z4.scid | 2014-12-11 12:23:06 HD Request # 11 | Downloading Intraday chart data for J7Z4 to the file J7Z4.scid. Service: ta | 2014-12-11 12:23:06 HD Request # 11 | Download start Date-Time: 2012-03-16 13:23:06.0 | 2014-12-11 12:23:06 HD Request # 11 | Using server: ds3.sierracharts.com port 10149 | 2014-12-11 12:23:06 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-12-11 12:23:06 Socket (784) | Connected. | 2014-12-11 12:23:06 HD Request # 11 | Sending historical data logon request message. | 2014-12-11 12:23:06 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\SierraChartTransActMA\Data\J7Z4.scid | 2014-12-11 12:23:06 HD Request # 11 | Requesting Intraday data. Start Date-Time: 2012-03-16 13:23:06. Record interval: 1. Symbol: J7Z4 | 2014-12-11 12:23:06 Socket (784) | Shutdown and closed. | 2014-12-11 12:23:06 The network socket for historical data has been closed. | 2014-12-11 12:23:06 HD Request # 11 | Error downloading historical Intraday data for J7Z4. Historical data file not available for symbol. | 2014-12-11 12:23:06 * HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for J7Z4 | 2014-12-11 12:23:06 HD Request # 11 | Intraday download COMPLETE for J7Z4. Completion time: 0s. Unique request ID: 10 | 2014-12-11 12:23:06 Removed historical data download ID 10 | 2014-12-11 12:23:06 Real-time Intraday chart data file updates started for J7Z4 | 2014-12-11 12:23:06 |
| [2014-12-12 07:10:07] |
We are going to be adding this symbol now. You will need to restart Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
