Date/Time: Tue, 27 Oct 2026 04:10:22 +0000
Custom Study DLL file not working on new computer
View Count: 1903
| [2014-12-10 16:25:31] |
| CMG - Posts: 179 |
Hello, I have a set of 4 custom studies (.dll file) 3 of them work and one of them does not work in my new computer. In the old computer all of them work fine. I, of course have looked at every possibility of why this happens and run out of options, any ideas? CMG |
| [2014-12-10 16:42:03] |
Do you see any error messages related to the DLL file in the Message Log?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-10 16:42:16
| [2014-12-10 18:25:28] |
| CMG - Posts: 179 |
Nop...
| [2014-12-10 21:39:17] |
| CMG - Posts: 179 |
Since this is a new computer I decided to install the whole study including the .ccp file and compile it again. It says the following message : None of the selected source files contains the SCDLLName line at the top of the file. Refer to ACSIL documentation. I do have the SCDLLName, and as I mention 3 of the studies on the same file work and one doesnot work. So this message is wrong since you just need 1 SCDLLName per file. Let me know what do you think. CMG |
| [2014-12-12 18:53:15] |
We really need to get the CPP source code and test this to see what the problem is. You can attach it here as a private attachment. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
