Date/Time: Mon, 05 Oct 2026 03:12:26 +0000
[User Discussion] - Uptick and downtick to volume ratio
View Count: 6346
[2014-12-06 05:28:18]
Dom7364 - Posts: 258
Is there an existing study or a way to have the equivalent, to calculate the uptick and downtick to volume ratio? In other words, how much volume/market order does it take to make the price go up one tick and do down one tick at any given time?
[2014-12-06 15:49:32]
crazybears - Posts: 314
maybe this ?
http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s230
[2014-12-06 16:33:07]
Thanks crazy bear. This is bid vs ask volume, but what I am trying to highlight is how much volume it takes to uptick and to downtick..
[2014-12-06 17:10:56]
Sawtooth - Posts: 4355
This is the Spreadsheet Study study formula that replicates the Bid Ask Volume Ratio study when using an EMA:
=((100*(AA3-AC3)/(AA3+AC3))-L4)*(2/(1+$L$1))+L4
where:
the formula in is cell L3
AA3 is the Ask Volume study
AC3 is the Bid Volume study
L1 is the EMA length
You could modify this formula to create a ratio between the Uptick Volume study and the Ask Volume study, e.g., or between any two volume studies.:
Ask Volume
Bid Volume
Number of Trades - Ask
Number of Trades - Bid
Uptick Volume
Downtick Volume
Volume
Attached is an example spreadsheet and study collection. Put both in your Sierra Chart \Data folder. On a blank chart, go to Analysis >> Buy Sell Ratios-
attachmentBuy Sell Ratios-.StdyCollct - Attached On 2014-12-06 17:10:19 UTC - Size: 53.14 KB - 1449 views
attachmentBuy Sell Ratios.scwbf - Attached On 2014-12-06 17:10:36 UTC - Size: 123.18 KB - 1322 views
[2014-12-07 00:29:21]
nioko54130 - Posts: 108
Hi Dom!
To get this sort of features, you have to compare the ask volume with the downtick volume or the bid volume with the uptick volume in order to obtain a delta which calculates for example the difference of these to kind of volume
For example, if you have 200 ask market contract, and 100 bid market contract in a range barre, and then you have 150 uptick volume and 150 down tick volume in this same range barre ; you will get a "deltatick" of -50 : it means that 50 ask market contract have downticked the price inside of this range barre.
You can do this with the "studie subgraph difference" to obtain a visuel representation of this ; then you can use an other tool that i can send to you to convert this visual information in numerical information on your footprint chart.
[2014-12-07 04:16:19]
This may not be exactly what you are looking for but look at the Up/Down Volume Ratio study:
http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s315
However, if you look at the source code for it, you can modify it to meet your requirements. Here are instructions:
https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html
[2014-12-07 11:21:54]
Hi nioko54130
do you mean dowtickvolume - askvolume and uptickvolume - bid volume ?
[2014-12-07 13:04:21]
Hi crazybears,
We can do this too yes,
the goal is to compare the "bid and ask market volume" with the "up and down tick volume".
Then, you can compare it as you want to do
[2014-12-10 07:27:47]
I can't seem to find uptick volume and downtick volume..
